Adding option for users to login on checkout?
bill
Post by bill » 26 May 2017, 17:57
currently I have installed Aimeos and when you add a product to basket and click on "check" , it goes to the checkout page /checkout
is there away to give the user the option to login? or checkout as Guest?
Re: Adding option for users to login on checkout?
Post by aimeos » 29 May 2017, 09:55
Checkout as guest is the default if the user isn't logged in. You can either add a login box to the basket or checkout page template or you can create an intermediate page between basket and checkout where the customer can explicitly decide. In the later case, you need to reconfigure the named route to the checkout in the basket controller.
