Removing product from car tgetting me error
bill
Post by bill » 30 May 2017, 18:56
Hi
I am getting this strange error when I remove products from my cart
Product with array key "0" not available
any idea why?
Re: Removing product from car tgetting me error
Post by aimeos » 30 May 2017, 20:33
Which basket plugins are activated and what's their configuration? Can you please post a screenshot?
bill
Post by bill » 31 May 2017, 15:52
check the error , I am not sure what you mean which basket plugin is activated? I am just using Aimeos with Laravel
see screenshot of the error
Post by aimeos » 31 May 2017, 17:52
We would need a screenshot of the admin interface, to be more precise from the Plugin tab of the Expert Mode which lists the active basket plugins.
bill
Post by bill » 31 May 2017, 18:07
I am using 2017 version
"require": {
"php": ">=5.6.4",
"aimeos/aimeos-laravel": "~2017.04",
see screen shot
Admin - Plugins area.png (137.11 KiB) Viewed 11669 times
Post by aimeos » 31 May 2017, 20:49
Everything looks quite normal. Does this error always occur when you delete a product from the basket? If yes, does it happen when using the demo data or only for your own products? Can you describe the steps to reproduce the error?
I guess it's related to the data and happens due to one of the basket plugins. You can also try to deactivate one plugin after another and see if the problem occurs again.
bill
Post by bill » 31 May 2017, 21:16
After updating aimeos and ai-payment to "dev-master" , I am missing the option to removed a product from cart and also to remove the added coupon code?
I cant test this feature any idea why?
Post by aimeos » 01 Jun 2017, 10:06
You need the new Laravel views in "./resources/views/vendor/shop/" because Aimeos uses FontAwesome now for all icons. Delete the directory if you haven't changed the files inside and execute
php artisan vendor:publish
bill
Post by bill » 01 Jun 2017, 16:23
Great Thnaks
