Aimeos without tax extension very useless
pete
Post by pete » 30 Jun 2017, 20:39
Also tried to work with multiple sites leads to a bad feeling in using aimeos, but maybe i have to buy another extension :lol:
Re: Aimeos without tax extension very useless
Post by aimeos » 01 Jul 2017, 10:40
The tax extension from the Aimeos company is only necessary if you want to do B2B or mixed B2B/B2C commerce (maybe also for EU/US wide B2C commerce where you have different tax rates per country/states).
Your criticism about multiple sites is very global and not helpful to improve things. What exactly do you want to do and what are the problems you've faced?
pritisinghip
Post by pritisinghip » 05 Apr 2018, 11:59
The Internal Revenue Service allows taxpayers to file for a 6-month extension if they need more time to prepare their tax return. You can obtain a tax extension for any reason; the IRS grants them automatically as long as you complete the proper form on time. Check your state tax laws; some states accept IRS extensions while others require you to file a separate state extension form.
martinaiphs
Post by martinaiphs » 25 Apr 2018, 12:12
If you don't have all of the documentation you need to meet the standard tax filing deadline of April 17, or if you just need a little more time to get your return submitted, a tax extension can get you more time to file. A tax extension gives you an additional six months to file, and because Tax Day is ordinarily on April 15, the extended tax deadline for 2018 is Oct. 15.
Filing for an extension is rather easy. You can do it by filing IRS Form 4868 — also known as the Application for Automatic Extension of Time to File U.S. Individual Income Tax Return. You can submit it either in paper form or online, and if you file your taxes with a software program, such as TurboTax, there's often a way to file through your chosen program as well.
Filing a tax extension is completely free. And as the name of the form implies, in most cases, an extension is automatically granted — meaning that there are no special qualifications you need to meet. Any taxpayer who requests the additional time is typically granted the extension.
