Decorator does not retrieve basket items any more
Innonic
Post by Innonic » 24 Aug 2017, 10:38
I got a new problem. I didn't change anything concerning my decorator (at least I'm not aware I did something).
The decorator worked fine before.
Now it seems it can't retrieve the items of the basket any more:
sizeof($propertyManager->searchItems( $search ))
returns 0.
That causes weight, size, etc. to be 0 which causes wrong delivery costs...
Right now I don't know where to start. What could have happened here?
I didn't change the item properties either...
Re: Decorator does not retrieve basket items any more
Post by aimeos » 25 Aug 2017, 07:57
Can you post your decorator's code? I guess the problem is in your data because I'm also not aware of any change that would cause this problem.
Innonic
Post by Innonic » 25 Aug 2017, 09:46
I found the problem. I was wrong with what I said, I DID make a change: I renamed the property type code of products and forgot to adapt that in the decorator.
I really feel ashamed of having opened an issue for that. So please accept my apology. :oops:
