Attributes not visible on product page
I added attributes of two types to an article: 'Configurable' and 'Default'.
The configurable attributes are there and configurable. But there's only one of the 'Default' attributes visible (see images).
I just startet adding the 'Configurable' attributes. Before I did that, the 'Default' atrributes were visible and for the other articles, that have no configurables yet, the defaults are visible.
Is there any Interference or a limited number of attributes?
BTW: I did clear the caches and updated the site several times.
Thank you!
Thank you!
- bild2.png (35.42 KiB) Viewed 12369 times
- bild1.png (65.56 KiB) Viewed 12369 times
Re: Attributes not visible on product page
There's no limitation in the number of attributes per product or any interference between attribute types. Only for variant types, there's a soft limit of 32 variant attribute types per product on 32 bit platforms. Your setup looks fine from what I can see as long as the status of the attribute types and attribute items are all "enabled".
Can you please add a
at https://github.com/aimeos/ai-client-htm ... lt.php#L10
Maybe we can get closer to the issue when we see if the attributes are already missing there.
print_r( $attrMap );Maybe we can get closer to the issue when we see if the attributes are already missing there.
Yes, here's the result (formatted for better readability):
Seems like everything is there. May this be caused by the 'attribute.position' since it's always 0? Should not, since the position is for entries of the same type, but the missing types are different...
Array (
[Anwendungsbereich] => Array (
[102] => Aimeos\MShop\Attribute\Item\Standard Object (
[values:Aimeos\MShop\Attribute\Item\Standard:private] => Array (
[attribute.id] => 102
[attribute.siteid] => 1
[attribute.typeid] => 55
[attribute.domain] => product
[attribute.code] => application-area
[attribute.status] => 1
[attribute.position] => 0
[attribute.label] => Innen / Außen
[attribute.mtime] => 2017-06-30 15:18:32
[attribute.ctime] => 2017-06-30 15:13:49
[attribute.editor] => hplforum
[attribute.type] => Anwendungsbereich
[attribute.typename] => Anwendungsbereich
[listItems:Aimeos\MShop\Common\Item\ListRef\Base:private] => Array ( )
[refItems:Aimeos\MShop\Common\Item\ListRef\Base:private] => Array ( )
[sortedLists:Aimeos\MShop\Common\Item\ListRef\Base:private] => Array ( )
[prefix:Aimeos\MShop\Common\Item\Base:private] => attribute.
[basevals:Aimeos\MShop\Common\Item\Base:private] => Array (
[modified:Aimeos\MShop\Common\Item\Base:private] =>
[Brennbar] => Array (
[103] => Aimeos\MShop\Attribute\Item\Standard Object (
[attribute.id] => 103
[attribute.typeid] => 56
[attribute.code] => inflammable
[attribute.label] => Nein
[attribute.mtime] => 2017-07-01 10:30:58
[attribute.ctime] => 2017-07-01 10:30:58
[attribute.type] => Brennbar
[attribute.typename] => Brennbar
[Hitzebeständig] => Array (
[104] => Aimeos\MShop\Attribute\Item\Standard Object (
[attribute.id] => 104
[attribute.typeid] => 57
[attribute.code] => heat-resistant
[attribute.label] => bis 800 °C
[attribute.mtime] => 2017-08-28 12:49:50
[attribute.ctime] => 2017-07-01 10:32:18
[attribute.type] => Hitzebeständig
[attribute.typename] => Hitzebeständig
[Motiv] => Array (
[112] => Aimeos\MShop\Attribute\Item\Standard Object (
[attribute.id] => 112
[attribute.typeid] => 39
[attribute.code] => hpl-hsn-002-motiv
[attribute.label] => Blätter
[attribute.mtime] => 2017-08-28 11:20:09
[attribute.ctime] => 2017-08-28 11:18:01
[attribute.type] => Motiv
[attribute.typename] => Motiv
[121] => Aimeos\MShop\Attribute\Item\Standard Object (
[attribute.id] => 121
[attribute.code] => hpl-hsn-003-motiv
[attribute.label] => Anzeigetafel
[attribute.mtime] => 2017-08-28 12:00:21
[attribute.ctime] => 2017-08-28 12:00:21
)Re: Attributes not visible on product page
I'm using version 16.10.5
I just looked into Chrome's 'Code Inspector' again and I realized, that the HTML of the attributes is there (see image).
But it seems to be invisible due to the CSS 'display:none'...
Maybe that's a hint?
UPDATE:
I just added some "Configurable" attributes toan article. Before I did that, the "Default" attributes were visible. After adding them, the "Default" atrributes are not visible any more...
I guess, there must be a connection.
UPDATE:
- bild1.png (93.07 KiB) Viewed 12353 times
You've added those attributes to the article, not the selection product. Therefore, the attributes are only shown if exactly this article is chosen by selecting it's variant attributes.
OK, I think I understand what you mean.
I do not have any attributes of type "Variant". I only have "Default", "Configurable" and "Custom value" attributes.
So what do I have to change now? Changing the type to "Selection" instead of "Article" doesn't help.
And why are some attributes shown and others are not? I created and added them the same way.
UPDATE:
By trial and error I realized, that I can create new attribute types and add them to the same article and they are visible.
So I deleted the attributes (the whole type) which were not shown. Afterwards I recreated them, added them and now they are visible again. That seems to work for now. But I can't do this for every article and attribute, whenever some article doesn't show all attributes...
Maybe there is some flag or something set wrong within the database. Probably it's what you mentioned above. Maybe you could explain that quickly to me in one or two more sentences. I don't really get it since I have no variants and it doesn't seem to make a difference if the articles type is "Selection" or "Article"...
UPDATE:
Please make sure that
- your articles are of product type "default"
- you don't have associated products to that articles of list type "default" (only suggest or bought)
The problem most probably arises because you've associated products to your articles (product detail panel -> Products) with a list type of "default". Those references are then interpreted as articles of a selection product and their attributes get the class "subproduct" which is hidden by default.
This is it!
THANK YOU!!!
THANK YOU!!!
