Trigger Jobs with REST API
DirkDittmar
Post by DirkDittmar » 01 Sep 2017, 14:45
first of all I have to admit that I'm absolutely new to Aimeos and I'm not very good at PHP. So sorry if this is a stupid question. I'm using 2017.07.4 (core) with Slim 3.8.1 and PHP 7.0 ...
I have to trigger the jobs through a REST API.
I've looked at
jobs.php
and of cause I looked at
\Aimeos\Slim\Command\Jobs
. My idea was to do something like the
\Aimeos\Slim\Command\Jobs::execute()
method. The problem is that I can not get the required objects.
Any idea welcome :)
Regards,
Dirk
Re: Trigger Jobs with REST API
Post by aimeos » 03 Sep 2017, 08:13
You will get into maximum execution time problems if you execute the jobs from a web environment. Instead, you should store the job requests in a file or the database and execute the jobs by a cronjob regularly depending on the stored requests.
DirkDittmar
Post by DirkDittmar » 03 Sep 2017, 09:07
Maybe I missunderstand your answer.
But I can not execute cronjobs on the server. So I have to trigger them on a different way.
Post by aimeos » 04 Sep 2017, 08:46
You can copy the jobs.php file and remove the check for the CLI environment. But be careful to protect the new script by HTTP auth or something similar. Otherwise, everybody can execute all jobs.
