Override ext/ai-laravel
bill
Post by bill » 06 Oct 2017, 22:29
Hi
I am trying to override this file here >> ext/ai-laravel/lib/custom/config/mshop/customer.php
is that possible I want to add it to my own ext folder
please help
Re: Override ext/ai-laravel
Post by aimeos » 07 Oct 2017, 10:55
Yes, create a file "mshop.php" in the "./lib/custom/config/" directory of your extension with the same array structure and add the SQL statements you want to overwrite.
bill
Post by bill » 07 Oct 2017, 17:44
What about the files here
Ext/ai-Laravel/lib/src/Mshop/Customer/Manager/Laravel.php. Can I over ride these ??
bill
Post by bill » 07 Oct 2017, 17:56
I created that file mshop.php and I changed the query but it's still not working ? Does it suppose to be mshop.php ?
Post by aimeos » 08 Oct 2017, 15:53
You can overwrite the manager class to. Create a new class in your extension in the
./lib/custom/src/MShop/Customer/Manager/Myproject.php
extend from
\Aimeos\MShop\Customer\Manager\Laravel
and overwrite the methods you need. Afterwards, configure your shop to use your new class with
https://aimeos.org/docs/Configuration/C ... nager/name
bill
Post by bill » 09 Oct 2017, 15:59
what about this
its still doesnt work.
I am trying to do the command line :
php artisan aimeos:account test@email.com --admin
and I am getting an error coming from ext/ai-laravel/custom/config/mshop/customer.php , ( I dont want to edit this file here to fix the error) I need to override it
so I override it in my ext/mydir/lib/custom/config/mshop.php but its not picking up that one?
Post by aimeos » 10 Oct 2017, 09:13
To enforce the correct order, please add "ai-laravel" to the "depends" section in the manifest.php of your project specific extension:
	'depends' => array(
		'aimeos-core',
		'ai-admin-extadm',
		'ai-admin-jqadm',
		'ai-admin-jsonadm',
		'ai-client-html',
		'ai-client-jsonapi',
		'ai-controller-jobs',
		'ai-laravel',
Here's an example file for your "./ext/mydir/lib/custom/config/mshop.php":
<?php
return array(
	'customer' => array(
		'manager' => array(
			'laravel' => array(
				'insert' => array(
					'ansi' => '
						INSERT INTO "users" (
							"siteid", "name", "company", "vatid", "salutation", "title",
							"firstname", "lastname", "address1", "address2", "address3",
							"postal", "city", "state", "countryid", "langid", "telephone",
							"telefax", "website", "email", "longitude", "latitude", "label",
							"birthday", "status", "vdate", "password",
							"updated_at", "editor", "created_at"
						) VALUES (
				'update' => array(
					'ansi' => '
						UPDATE "users"
						SET "siteid" = ?, "name" = ?, "company" = ?, "vatid" = ?,
							"salutation" = ?, "title" = ?, "firstname" = ?, "lastname" = ?,
							"address1" = ?, "address2" = ?, "address3" = ?, "postal" = ?,
							"city" = ?, "state" = ?, "countryid" = ?, "langid" = ?,
							"telephone" = ?, "telefax" = ?, "website" = ?, "email" = ?,
							"longitude" = ?, "latitude" = ?, "label" = ?, "birthday" = ?,
							"status" = ?, "vdate" = ?, "password" = ?, "updated_at" = ?, "editor" = ?
						WHERE "id" = ?
