Stock not working
Bevi
Stock not working
Post by Bevi » 11 Oct 2017, 18:32
Whenever I try to buy any of my products I get these two errors:
-Products out of stock
-product.stock.notenough
Here's my mapping:
    $mapping = [
			'item' => [
						1 => 'product.label', // UTF-8 encoded text, also used as product name
						2 => 'product.type', // type of the product, e.g. "default" or "selection"
						3 => 'product.status', // enabled (1) or disabled (0)
					'text' => [
						6 => 'text.type', // e.g. "short" for short description
						7 => 'text.content', // UTF-8 encoded text
						8 => 'text.languageid',
						9 => 'text.type', // e.g. "short" for short description
						10 => 'text.content', // UTF-8 encoded text
						11 => 'text.languageid',
					'media' => [
						12 => 'media.type',
						13 => 'media.url', // relative URL of the product image on the server
						14 => 'media.type',
						15 => 'media.url', // relative URL of the product image on the server
						16 => 'media.type',
						17 => 'media.url', // relative URL of the product image on the server
						18 => 'media.type',
						19 => 'media.url', // relative URL of the product image on the server
						20 => 'media.type',
						21 => 'media.url', // relative URL of the product image on the server
					'price' => [
						//32 => 'price.quantity', // the quantity the price is valid from (for block pricing)
						22 => 'price.type',
						23 => 'price.value', // price with decimals separated by a dot, no thousand separator
						24 => 'price.currencyid',
						25 => 'price.taxrate', // tax rate with decimals separated by a dot
					'attribute' => [
					'product' => [
						14 => 'product.code', // e.g. EAN code of another product
						15 => 'product.lists.type', // e.g. "suggestion" for suggested product
					'property' => [
						16 => 'product.property.value', // arbitrary value for the corresponding type
						17 => 'product.property.type', // e.g. "package-weight"
					'catalog' => [
						26 => 'catalog.code', // e.g. Unique category code
						//19 => 'catalog.lists.type', // e.g. "promotion" for top seller products
					'stock' => [
						27 => 'product.stock.stocklevel', // e.g. Unique category code
						28 => 'product.stock.warehouseid',
and the first record of my csv:
0002-03VE,Modellismo,default,1,short,Carisma,short,GT24T MICRO 4WD MONSTER TRUCK/ RTR,fr,short,GT24T MICRO 4WD MONSTER TRUCK/ RTR  ,de,default,../../grafica/FotoModellismo/Neidhardt/0002-03VE_1.jpg,default,../../grafica/FotoModellismo/Neidhardt/0002-03VE_2.jpg,default,../../grafica/FotoModellismo/Neidhardt/0002-03VE_3.jpg,default,../../grafica/FotoModellismo/Neidhardt/0002-03VE_4.jpg,default,../../grafica/FotoModellismo/Neidhardt/0002-03VE_5.jpg,default,0,CHF,8,3,100000,default
Re: Stock not working
Post by aimeos » 11 Oct 2017, 20:35
Which version of the Aimeos package are you using?
Bevi
Post by Bevi » 13 Oct 2017, 21:33
aimeos wrote:Which version of the Aimeos package are you using?
Laravel 2017.07.3
Post by aimeos » 14 Oct 2017, 09:25
Sorry, the documentation wasn't up to date: It must be "stock.stocklevel" and "stock.type"
It's now correct: https://aimeos.org/docs/Developers/Cont ... _CSV#Stock
