Show Categories in catalog/lists/body-default.php
i have a Template where i need a sidebar on each view on the left side.
In the Listview i need left the categoryview, Searchview and the mini basket in the detail view too so how can i do that?
Re: Show Categories in catalog/lists/body-default.php
I also dont understand how i can just add under the search input field an simple basket-button with the target configured in the minicart.
its all a little bit confusing and its not really a typo3-extension. was aimeos not early coded in extbase?
by the way: how can i use partials? where i find the params i can give here:
i try to add the category with partials but the list was empty.....
$pagination = $this->partial(
$this->config( 'client/html/catalog/lists/partials/pagination', 'catalog/lists/pagination-default.php' ),
array(
'params' => $params,
'size' => $this->get( 'listPageSize', 48 ),
'total' => $this->get( 'listProductTotal', 0 ),
'current' => $this->get( 'listPageCurr', 0 ),
'prev' => $this->get( 'listPagePrev', 0 ),
'next' => $this->get( 'listPageNext', 0 ),
'last' => $this->get( 'listPageLast', 0 ),
) <!-- where is this array documented????? ############################################
);Re: Show Categories in catalog/lists/body-default.php
Do you want to display the mini basket itself under the search field or a (list of) product(s)?mantik wrote:I also dont understand how i can just add under the search input field an simple basket-button with the target configured in the minicart.
Aimeos is still based on extbase but uses only the MVC part. This is because Aimeos is in fact a PHP library whose object methods are called in the actions.mantik wrote:its all a little bit confusing and its not really a typo3-extension. was aimeos not early coded in extbase?
For the common partials, they are documented in the partials itself like here:mantik wrote:by the way: how can i use partials? where i find the params i can give here:
https://github.com/aimeos/ai-client-htm ... n/partials
For the catalog list pagination partial, this isn't the case. You have to look into the partial what is used by $this->get()
But the example used for pagination is no where documented... Can i just use this common partials or how you know how to set up this pagination from catalog/lists/body-default.php
Whats the logic?
Here a specific question:
What must i do if i want display the categories tree (or the whole filter module) in the template of product list (catalog/lists/body-default.php)?
In typo3 there are several aimeos-content-elements. So all i want is to say: show the aimeos category and the minibasket in the aimeos product list.
Whats the logic?
- Backend
- Bildschirmfoto vom 2017-10-24 06-19-27.jpg (33.21 KiB) Viewed 20063 times
- Frontend
- Bildschirmfoto vom 2017-10-24 06-20-56.jpg (109.2 KiB) Viewed 20063 times
mantik wrote:But the example used for pagination is no where documented... Can i just use this common partials or how you know how to set up this pagination from catalog/lists/body-default.php
'params' => $params, // Associative list of additional parameters for the URL, e.g. "[f_catid => 1]"
'size' => $this->get( 'listPageSize', 48 ), // products per page
'total' => $this->get( 'listProductTotal', 0 ), // total number of products
'current' => $this->get( 'listPageCurr', 0 ), // current page number starting from "1"
'prev' => $this->get( 'listPagePrev', 0 ), // previous page number
'next' => $this->get( 'listPageNext', 0 ), // next page number
'last' => $this->get( 'listPageLast', 0 ), // last page number
You can't merge the category tree into the list template easily. But you can place the catalog filter plugin above the catalog list plugin on your page by moving the content element in the TYPO3 backend.mantik wrote:What must i do if i want display the categories tree (or the whole filter module) in the template of product list (catalog/lists/body-default.php)?
The Pagination snippet was just a example. I ask where i find this in the documentation. in the hope to find the rest of posibilities there...
somethin like $categories = getCatalogTree($basketPid, $etc) or instance an Object etc...
not posible? also not over partials?
of cors must not be in the backend. i will just active the list and disable the other both and just output a minibasket, a category tree and a product list.
a pity... i've really hope typo3 has now a good shopsolution too... but if you can't call a modul as sub its not really flexible.
and some things works in laravel, some in symfony but in typo3 not etc...
very confusing
I know that but thats no what i want... i wouldn't ask if i need this kind of solution.You can't merge the category tree into the list template easily. But you can place the catalog filter plugin above the catalog list plugin on your page by moving the content element in the TYPO3 backend.
very confusing
The parameters for partials that are meant for being used by several templates are documented in the head of the partial files: https://github.com/aimeos/ai-client-htm ... n/partialsmantik wrote:The Pagination snippet was just a example. I ask where i find this in the documentation. in the hope to find the rest of posibilities there...
OK, in case you want to write some code, you have all possibilities you needmantik wrote:I know that but thats no what i want... i wouldn't ask if i need this kind of solution.
- Create a new decorator class: https://aimeos.org/docs/Developers/Html ... components
- Implement the setViewParams() method and add your code to retrieve the categories and add them the tree to the view there
- You can have a look into the catalog filter tree client for a working code example: https://github.com/aimeos/ai-client-htm ... d.php#L216
- Basically, you only need this method: https://github.com/aimeos/ai-controller ... rd.php#L75
- Configure your decorator to be wrapped around the catalog/lists component
- Now you have the data you've added to the view available in the lists template
In general, you should have a deep look into the documentation how to adapt the frontend. That will give you some good hints how to change things: https://aimeos.org/docs/Developers#Frontend
Sorry, wasn't sure at first if you were able to dig deeper into Aimeos to extend the code basemantik wrote:a pity... i've really hope typo3 has now a good shopsolution too... but if you can't call a modul as sub its not really flexible. and some things works in laravel, some in symfony but in typo3 not etc...
You can adapt Aimeos to every requirement you need because its build from the ground up for that. There are some minor differences between the integrations as you state because not all frameworks supports everything. Like you said, it's possible to call a controller in a Symfony template but that's not supported in TYPO3 as far as I know.
