How extendable is Aimeos?
DimaUlyanets
Post by DimaUlyanets » 04 Nov 2017, 23:14
Hey!
First of all, demo looks really good, looks very promising.
I'm looking for e-commerce solution that's very extendable. Not something like shopify with customization, but with real coding, making drastic changes like changing search engine or including payment gateway, changing registration/login flow, etc. Is Aimeos a good solution for that?
Also is there any projects that use Aimeos in production?
Thanks in advance!
Re: How extendable is Aimeos?
Post by aimeos » 05 Nov 2017, 11:41
Aimeos is exactly build for that: To extend, modify, remove and add any feature/behavior you need. You can not only use Aimeos for online shops but also for any other e-commerce related project.
Here's the Aimeos software stack for a quick overview of the system:
https://aimeos.org/docs/Developers/Software_stack
There are many articles for developers related to changing and adapting Aimeos:
Here you can find a list of web sites using Aimeos we know from:
https://aimeos.org/project/showcases/
DimaUlyanets
Post by DimaUlyanets » 05 Nov 2017, 19:09
Thanks for useful links! Will definitely try Aimeos. Cheers!
