database schema
Doveman
database schema
Post by Doveman » 09 Nov 2017, 22:33
I am on Linux with Symfony 3.3, php5 and the Lastest version of Aimeos.
Two questions:
1. Where are the database schemas located?
2. When I want to modify the extensions where do I put the mods.
Re: database schema
Post by aimeos » 09 Nov 2017, 22:40
Doveman wrote: 1. Where are the database schemas located?
Core: https://github.com/aimeos/aimeos-core/t ... ult/schema
FOSuser: https://github.com/aimeos/ai-fosuser/tr ... ult/schema
Doveman wrote: 2. When I want to modify the extensions where do I put the mods.
Always in your own extension: https://aimeos.org/docs/Developers/Create_an_extension
There's an extension generator available that will create one for you: https://aimeos.org/developer/extensions/
Doveman
Re: database schema
Post by Doveman » 10 Nov 2017, 01:09
Ok Thanks. Dos that unpack into the ext folder?
Re: database schema
Post by aimeos » 10 Nov 2017, 11:47
The Aimeos core is in ./vendor/aimeos/aimeos-core/, all Aimeos extensions are in the ./ext/ folder. This leads to a lean core and extension can be easily added or removed.
