Show/Hide html code
Bevi
Show/Hide html code
Post by Bevi » 10 Nov 2017, 17:42
Laravel 2017.10
Hello Sir,
I would like to show and hide anchors in the app.blade.php, depending on the category id.
How am I supposed to check the id number?
Re: Show/Hide html code
Post by aimeos » 12 Nov 2017, 11:27
It's better to use the category codes as they usually don't change
Bevi
Post by Bevi » 13 Nov 2017, 12:33
aimeos wrote:It's better to use the category codes as they usually don't change
Sir, I do use category codes (the catalog ones), I just want to create some if statement to check them.
Something like:
@php $_GET['f_catid'];
				if($_GET["f_catid"] == 15)
but meant for blade files.
I tried
Input::get('f_catid')
But I get the following error: Class "input" not found... :oops:
Post by aimeos » 13 Nov 2017, 16:07
Are you using a Blade template? if yes, have you tried "\Input" instead? Might be a namespacing issue in this case.
If you are using the standard Aimeos PHP template engine, you have to use "$this->param( 'f_catid' )" instead.
