problem on admin page
I go issue with the admin page, when login, i get this corrupt interface. (attached pic)
Any idea what the prob?
- aimeos.jpg (102.27 KiB) Viewed 6811 times
Re: problem on admin page
Can you please open the console of your browser and have a look if there are any Javascript errors or some XHR requests that are failing?
I have check on the browser console, and get the errors as below,
cdnjs.cloudflare.com/ajax/libs/jqueryui/1.12.1/jquery-ui.min.css Failed to load resource: net::ERR_INSECURE_RESPONSE
cdnjs.cloudflare.com/ajax/libs/tether/1.4.0/css/tether.min.css Failed to load resource: net::ERR_INSECURE_RESPONSE
cdnjs.cloudflare.com/ajax/libs/font-awesome/4.7.0/css/font-awesome.min.css Failed to load resource: net::ERR_INSECURE_RESPONSE
jquery.min.js Failed to load resource: net::ERR_INSECURE_RESPONSE
jquery-ui.min.js Failed to load resource: net::ERR_INSECURE_RESPONSE
d3.min.js Failed to load resource: net::ERR_INSECURE_RESPONSE
modernizr.js Failed to load resource: net::ERR_INSECURE_RESPONSE
tether.min.js Failed to load resource: net::ERR_INSECURE_RESPONSE
ckeditor.js Failed to load resource: net::ERR_INSECURE_RESPONSE
jquery.js Failed to load resource: net::ERR_INSECURE_RESPONSE
bootstrap.min.js:6 Uncaught Error: Bootstrap's JavaScript requires jQuery. jQuery must be included before Bootstrap's JavaScript.
at bootstrap.min.js:6
js:141 Uncaught ReferenceError: jQuery is not defined
at js:141
Any idea on how what this mean? something to do with the refer js link?
at js:141
There seems to be some proxy between you and the CDN which modifies the data so the hashes don't match any more.
If you can't get around this, you can try to replace "https" by "http" or remove the "integrity" attribute in the "link" and "script" tags in a local copy of this file in ./resources/views/vendor/shop/jqadm/: https://github.com/aimeos/aimeos-larave ... .blade.php
By changing the https to http, prob solved. thanks !
