How to change the HTML-Template
chricken
Post by chricken » 20 Nov 2017, 05:10
as anyone else, I am using the elegance-template and edit the CSS.
That is okay for the first steps, but now I want to add additional info into the list view and change some other things, where changing the CSS just isn't enough.
Unfortunately in the folder ext/aimeos/Resources/Public/Themes/elegance there is no HTML or similar available.
So I wonder, if and how I can change the structure of the theme.
Regards
Christian
PS: I am using Aimeos 17.10.2pre under Typo3 8.7.8 with PHP 7.0.20
Re: How to change the HTML-Template
Post by aimeos » 20 Nov 2017, 22:16
Please create a new Aimeos extension for your project (https://aimeos.org/developer/extensions/) and place the modified templates in the same directory structure as in the Aimeos HTML client. You can find articles for all you will need in the docs: https://aimeos.org/docs/TYPO3#Frontend
