attribute type selection for configurable options
antonlinderer
Post by antonlinderer » 24 Nov 2017, 18:29
Is there a way to define in config/shop.php a radio type for attributes that are configurable options such as for variant attributes as described in the docs?
Re: attribute type selection for configurable options
Post by aimeos » 24 Nov 2017, 21:23
Unfortunately not, mostly because options can have it's own price. But you can overwrite the partial template and add generate them the way you want: https://github.com/aimeos/ai-client-htm ... t.php#L191
