Select Menu Layout
mattdev
Select Menu Layout
Post by mattdev » 27 Nov 2017, 17:12
Is there a way to orgranize the selection menu like Amazon does. Please see the image for details. Thanks!
Re: Select Menu Layout
Post by aimeos » 27 Nov 2017, 22:17
For each attribute type, you can choose that they should be displayed either as select box or (like you want) as radio buttons: https://aimeos.org/docs/Configuration/C ... ction/type
If you need to adapt the HTML code, overwrite this template:
https://github.com/aimeos/ai-client-htm ... efault.php
