User is older then 18? Age check
chricken
Post by chricken » 08 Dec 2017, 14:04
my shop is all about selling wine (and liqueur later).
I am wondering, if there is a way to restrict orders to people older then 18 years.
Maybe a decorator could help me out or there is an option, I haven't found.
Regards
Christian
Re: User is older then 18? Age check
Post by aimeos » 09 Dec 2017, 18:54
You can only restrict access if you've checked on a different way that the customer is already 18.
You can enable the birthday field in the checkout process, but customers can enter any value in that field:
https://aimeos.org/docs/Configuration/C ... orm_fields
Alternatively, you can add a checkbox in the checkout summary so the customers must confirm that they are at least 18 years old.
