Default status "delivery"
Kevin
Post by Kevin » 11 Dec 2017, 09:26
How do I change the default delivery status?
By default this is set to -1 in the file /Applications/MAMP/htdocs/snackup/vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Order/Item
	 * Unfinished delivery.
	 * This is the default status after creating an order and this status
	 * should be also used as long as technical errors occurs.
	const STAT_UNFINISHED = -1;
As I can not change files in the "vendor" folder, how do I change this value to 4.
Thanks in advance!
Regards,
Kevin
Re: Default status "delivery"
Post by aimeos » 13 Dec 2017, 00:04
Write a small delivery service provider that sets the delivery status according to your needs and use it in the checkout process:
https://github.com/aimeos/aimeos-core/b ... al.php#L32
Note: You have to execute the "./artisan aimeos:jobs order/service/delivery" command regularly to set the status (https://aimeos.org/docs/Laravel/Configure_cronjobs)
