Translate card errors
Kevin
Post by Kevin » 28 Dec 2017, 09:00
How is it possible to translate errors when validating the card info in the checkout. Errors like:
Card has expired
Your card's security code is invalid.
Thanks !
K.
Re: Translate card errors
Post by aimeos » 29 Dec 2017, 12:43
If the error messages are returned by Stripe, you should pass the ISO language code via the Stripe API so Stripe returns error messages for that language. In case you want to do some local checks and return errors before sending the data to Stripe, you can use the translate view helper to translate error messages to other languages via the config:
<?= $this->translate( 'client', 'Card number invalid' ); ?>
https://aimeos.org/docs/Laravel/Overwrite_translations
