Translation issue
webshade
Translation issue
Post by webshade » 29 Dec 2017, 14:04
HI there,
I've a strange problem. I can't overwrite one language label.
This is my setup:
plugin.tx_aimeos.settings.i18n.nl {
1 {
domain = client
string = address
trans = Uw gegevens
2 {
domain = client
string = delivery
trans = Afhalen
3 {
domain = client
string = summary
trans = Coupons
4 {
domain = client
string = Your comment
trans = Afhaaltijd
5 {
domain = client
string = We have received your payment, and will take care of your order immediately.
trans = We hebben je bestelling ontvangen en zullen direct verder gaan met de verwerking.
Number 5 won't be translated in email.
What to do?
Thanks,
Raymond
Re: Translation issue
Post by aimeos » 29 Dec 2017, 14:23
TYPO3 requires separate configuration for frontend, backend and scheduler tasks. To overwrite translations in the e-mails, you have to put those translations into the TS-Config field of the scheduler task that will send the e-mails.
webshade
Post by webshade » 29 Dec 2017, 14:52
Thanks for your reply.
Can I just copy this code to the scheduler task or does it have another code?
Post by aimeos » 30 Dec 2017, 14:31
You can copy the TypoScript code to the TS-Config field of the scheduler task. It will be accepted with the "plugin.tx_aimeos." prefix even if it's not required.
