Can not start the site after installation Aimeos.
netman2002
Post by netman2002 » 17 Jan 2018, 09:21
After instalation the Aimeos I try to start it: http://test.inf-tec.ru/list - error occured
This error occurs when processing the 'aimeos/ext/ai-client-html/client/i18n/en' file
Extraction from the log file:
[2018-01-17 08:58:11] local.ERROR: unpack(): Type V: not enough input, need 4, have 0 {"userId":3,"email":"a@a.ru","exception":"[object] (ErrorException(code: 0): unpack(): Type V: not enough input, need 4, have 0 at /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/ext/ai-gettext/lib/custom/src/MW/Translation/File/Mo.php:189)
[stacktrace]
#0 [internal function]: Illuminate\\Foundation\\Bootstrap\\HandleExceptions->handleError(2, 'unpack(): Type ...', '/home/SHERLAND_...', 189, Array)
#1 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/ext/ai-gettext/lib/custom/src/MW/Translation/File/Mo.php(189): unpack('V939524098', '')
#2 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/ext/ai-gettext/lib/custom/src/MW/Translation/File/Mo.php(104): Aimeos\\MW\\Translation\\File\\Mo->readIntArray('V', 939524098)
#3 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/ext/ai-gettext/lib/custom/src/MW/Translation/File/Mo.php(47): Aimeos\\MW\\Translation\\File\\Mo->extract()
#4 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/ext/ai-gettext/lib/custom/src/MW/Translation/Gettext.php(134): Aimeos\\MW\\Translation\\File\\Mo->__construct('/home/SHERLAND_...')
#5 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/ext/ai-gettext/lib/custom/src/MW/Translation/Gettext.php(54): Aimeos\\MW\\Translation\\Gettext->getTranslations('admin')
#6 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Helper/Translate/Standard.php(57): Aimeos\\MW\\Translation\\Gettext->dt('admin', 'Dashboard')
#7 [internal function]: Aimeos\\MW\\View\\Helper\\Translate\\Standard->transform('admin', 'Dashboard')
#8 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(88): call_user_func_array(Array, Array)
#9 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/ext/ai-admin-jqadm/admin/jqadm/templates/dashboard/list-default.php(15): Aimeos\\MW\\View\\Standard->__call('translate', Array)
#10 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(251): include('/home/SHERLAND_...')
#11 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(233): Aimeos\\MW\\View\\Standard->includeFile('/home/SHERLAND_...')
#12 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/ext/ai-admin-jqadm/admin/jqadm/src/Admin/JQAdm/Dashboard/Standard.php(148): Aimeos\\MW\\View\\Standard->render('dashboard/list-...')
#13 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/ext/ai-admin-jqadm/admin/jqadm/src/Admin/JQAdm/Common/Decorator/Base.php(142): Aimeos\\Admin\\JQAdm\\Dashboard\\Standard->search()
#14 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/aimeos/aimeos-laravel/src/Aimeos/Shop/Controller/JqadmController.php(235): Aimeos\\Admin\\JQAdm\\Common\\Decorator\\Base->search()
#15 [internal function]: Aimeos\\Shop\\Controller\\JqadmController->searchAction('default', 'dashboard')
#16 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): call_user_func_array(Array, Array)
#17 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\\Routing\\Controller->callAction('searchAction', Array)
#18 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Route.php(212): Illuminate\\Routing\\ControllerDispatcher->dispatch(Object(Illuminate\\Routing\\Route), Object(Aimeos\\Shop\\Controller\\JqadmController), 'searchAction')
#19 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Route.php(169): Illuminate\\Routing\\Route->runController()
#20 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Router.php(658): Illuminate\\Routing\\Route->run()
#21 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(30): Illuminate\\Routing\\Router->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#22 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(41): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#23 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\\Routing\\Middleware\\SubstituteBindings->handle(Object(Illuminate\\Http\\Request), Object(Closure))
#24 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))
#25 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Auth/Middleware/Authenticate.php(43): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#26 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\\Auth\\Middleware\\Authenticate->handle(Object(Illuminate\\Http\\Request), Object(Closure))
#27 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))
#28 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(67): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#29 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\\Foundation\\Http\\Middleware\\VerifyCsrfToken->handle(Object(Illuminate\\Http\\Request), Object(Closure))
#30 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))
#31 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#32 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\\View\\Middleware\\ShareErrorsFromSession->handle(Object(Illuminate\\Http\\Request), Object(Closure))
#33 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))
#34 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(63): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#35 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\\Session\\Middleware\\StartSession->handle(Object(Illuminate\\Http\\Request), Object(Closure))
#36 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))
#37 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#38 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\\Cookie\\Middleware\\AddQueuedCookiesToResponse->handle(Object(Illuminate\\Http\\Request), Object(Closure))
#39 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))
#40 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(59): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#41 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\\Cookie\\Middleware\\EncryptCookies->handle(Object(Illuminate\\Http\\Request), Object(Closure))
#42 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))
#43 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(102): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#44 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Router.php(660): Illuminate\\Pipeline\\Pipeline->then(Object(Closure))
#45 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Router.php(635): Illuminate\\Routing\\Router->runRouteWithinStack(Object(Illuminate\\Routing\\Route), Object(Illuminate\\Http\\Request))
#46 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Router.php(601): Illuminate\\Routing\\Router->runRoute(Object(Illuminate\\Http\\Request), Object(Illuminate\\Routing\\Route))
#47 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Router.php(590): Illuminate\\Routing\\Router->dispatchToRoute(Object(Illuminate\\Http\\Request))
#48 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(176): Illuminate\\Routing\\Router->dispatch(Object(Illuminate\\Http\\Request))
#49 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(30): Illuminate\\Foundation\\Http\\Kernel->Illuminate\\Foundation\\Http\\{closure}(Object(Illuminate\\Http\\Request))
#50 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/fideloper/proxy/src/TrustProxies.php(56): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#51 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(149): Fideloper\\Proxy\\TrustProxies->handle(Object(Illuminate\\Http\\Request), Object(Closure))
#52 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))
#53 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(30): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#54 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle(Object(Illuminate\\Http\\Request), Object(Closure))
#55 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))
#56 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(30): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#57 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\\Foundation\\Http\\Middleware\\TransformsRequest->handle(Object(Illuminate\\Http\\Request), Object(Closure))
#58 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))
#59 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#60 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\\Foundation\\Http\\Middleware\\ValidatePostSize->handle(Object(Illuminate\\Http\\Request), Object(Closure))
#61 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))
#62 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php(46): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#63 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(149): Illuminate\\Foundation\\Http\\Middleware\\CheckForMaintenanceMode->handle(Object(Illuminate\\Http\\Request), Object(Closure))
#64 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\\Pipeline\\Pipeline->Illuminate\\Pipeline\\{closure}(Object(Illuminate\\Http\\Request))
#65 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(102): Illuminate\\Routing\\Pipeline->Illuminate\\Routing\\{closure}(Object(Illuminate\\Http\\Request))
#66 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(151): Illuminate\\Pipeline\\Pipeline->then(Object(Closure))
#67 /home/SHERLAND_AC/web/test.inf-tec.ru/laravel/aimeos/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(116): Illuminate\\Foundation\\Http\\Kernel->sendRequestThroughRouter(Object(Illuminate\\Http\\Request))
#68 /home/SHERLAND_AC/web/test.inf-tec.ru/public_html/index.php(55): Illuminate\\Foundation\\Http\\Kernel->handle(Object(Illuminate\\Http\\Request))
#69 {main}
How to fix this error?
Re: Can not start the site after installation Aimeos.
Post by aimeos » 17 Jan 2018, 09:47
Seems like there was a bit error while downloading the files. Remove "aimeos/ext/ai-client-html" and run "composer update" again.
netman2002
Post by netman2002 » 17 Jan 2018, 10:09
I did it.
aimeos# composer update
Loading composer repositories with package information
Updating dependencies (including require-dev)
Package operations: 1 install, 3 updates, 0 removals
- Updating ramsey/uuid (3.7.1 => 3.7.2): Downloading (100%)
- Updating laravel/framework (v5.5.28 => v5.5.31): Downloading (100%)
- Updating aimeos/ai-admin-jqadm (2017.10.15 => 2017.10.16): Downloading (100%)
- Installing aimeos/ai-client-html (2017.10.6): Loading from cache
Writing lock file
Generating optimized autoload files
> Illuminate\Foundation\ComposerScripts::postAutoloadDump
> @php artisan package:discover
Discovered Package: fideloper/proxy
Discovered Package: laravel/tinker
Discovered Package: aimeos/aimeos-laravel
Package manifest generated successfully.
> @php artisan vendor:publish --tag=public --force
Copied Directory [/vendor/aimeos/aimeos-laravel/public] To [/public/packages/aimeos/shop]
Publishing complete.
I am confused by the following: - Installing aimeos/ai-client-html (2017.10.6): Loading from cache
Nothing has changed, error is still occured.
netman2002
Post by netman2002 » 17 Jan 2018, 11:52
Let's go deeper...
File Mo.php contain a Mo class. I use the dd (dump and die) function in different places of Mo.php file.
Read the code below and read comments (dd function output)...
class Mo
const MAGIC1 = -1794895138;
const MAGIC2 = -569244523;
const MAGIC3 = 2500072158;
private $str;
private $strlen;
private $pos = 0;
private $messages = [];
* Initializes the .mo file reader
* @param string $filepath Absolute path to the Gettext .mo file
public function __construct( $filepath )
// dd( $filepath ) => .../aimeos/ext/ai-client-html/client/i18n/en
if( ( $str = file_get_contents( $filepath ) ) === false ) {
throw new \Aimeos\MW\Translation\Exception( sprintf( 'Unable to read from file "%1$s"', $filepath ) );
$this->str = $str;
$this->strlen = strlen( $str ); // dd( $this->strlen ) => 1497
$this->messages = $this->extract();
protected function extract()
$magic = $this->readInt( 'V' );
if( ( $magic === self::MAGIC1 ) || ( $magic === self::MAGIC3 ) ) { //to make sure it works for 64-bit platforms
$byteOrder = 'V'; //low endian
} elseif( $magic === ( self::MAGIC2 & 0xFFFFFFFF ) ) {
$byteOrder = 'N'; //big endian
} else {
throw new \Aimeos\MW\Translation\Exception( 'Invalid MO file' );
// dd( $byteOrder ) => "V"
$this->readInt( $byteOrder );
$total = $this->readInt( $byteOrder ); //total string count
// dd( $total ) => 469762048
$originals = $this->readInt( $byteOrder ); //offset of original table
// dd( $originals ) => 3019898880
$trans = $this->readInt( $byteOrder ); //offset of translation table
// dd( $trans ) => 486539264
$this->seekto( $originals );
// seekto function try to position the cursor to 3019898880 position, whereas length of string is 1497 ( $this->strlen )
$originalTable = $this->readIntArray( $byteOrder, $total * 2 ); // crash on this step
$this->seekto( $trans );
$translationTable = $this->readIntArray( $byteOrder, $total * 2 );
return $this->extractTable( $originalTable, $translationTable, $total );
Is 'en' file bad?
Or do I somehow do not properly set up the environment?
Post by aimeos » 17 Jan 2018, 23:26
Yes, most propably your "en" file is corrupt. Can you delete ".cache/composer/files/aimeos/" in your home directory so composer fetches the files again?
netman2002
Post by netman2002 » 18 Jan 2018, 06:23
I was delete this directories:
homedir/.composer/cache/files/aimeos
sitedir/aimeos/ext/ai-client-html
I was run update:
Package operations: 1 install, 2 updates, 0 removals
- Updating aimeos/aimeos-core (2017.10.10 => 2017.10.11): Downloading (100%)
- Updating aimeos/ai-admin-jqadm (2017.10.16 => 2017.10.17): Downloading (100%)
- Installing aimeos/ai-client-html (2017.10.6): Downloading (100%)
Writing lock file
Just in case, I cleaned the cache:
aimeos# php artisan cache:clear
Cache cleared successfully.
Problem still exists...
There is a en.zip in attachment. Please, compare 'en' file with your own.
en.zip
(924 Bytes) Downloaded 807 times
Post by aimeos » 18 Jan 2018, 09:24
The file seems OK. On which hardware/architecture do you want to run Aimeos?
netman2002
Post by netman2002 » 18 Jan 2018, 10:10
phpinfo: http://test.inf-tec.ru/i45875gfhdyte1256984.php
Also phpinfo in attachment.
aimeos# composer show
aimeos/ai-admin-extadm 2017.10.1 Aimeos ai-admin-extadm extension
aimeos/ai-admin-jqadm 2017.10.17 Aimeos ai-admin-jqadm extension
aimeos/ai-admin-jsonadm 2017.10.5 Aimeos ai-admin-jsonadm extension
aimeos/ai-client-html 2017.10.6 Aimeos ai-client-html extension
aimeos/ai-client-jsonapi 2017.10.3 Aimeos JSON API extension
aimeos/ai-controller-frontend 2017.10.5 Aimeos ai-controller-frontend extension
aimeos/ai-controller-jobs 2017.10.4 Aimeos ai-controller-jobs extension
aimeos/ai-gettext 2017.10.1 Aimeos Gettext extension
aimeos/ai-laravel 2017.10.1 Laravel adapter for Aimeos web shops and e-commerce solutions
aimeos/ai-swiftmailer 2017.10.1 SwiftMailer adapter for Aimeos web shops and e-commerce solutions
aimeos/aimeos-core 2017.10.11 Full-featured e-commerce components for high performance online shops
aimeos/aimeos-laravel 2017.10.3 Full-featured Laravel web shop package and e-commerce solution for high performance shops
composer/installers v1.5.0 A multi-framework Composer library installer
dnoegel/php-xdg-base-dir 0.1 implementation of xdg base directory specification for php
doctrine/annotations v1.4.0 Docblock Annotations Parser
doctrine/cache v1.6.2 Caching library offering an object-oriented API for many cache backends
doctrine/collections v1.4.0 Collections Abstraction library
doctrine/common v2.7.3 Common Library for Doctrine projects
doctrine/dbal v2.5.13 Database Abstraction Layer
doctrine/inflector v1.2.0 Common String Manipulations with regard to casing and singular/plural rules.
doctrine/instantiator 1.0.5 A small, lightweight utility to instantiate objects in PHP without invoking their constructors
doctrine/lexer v1.0.1 Base library for a lexer that can be used in Top-Down, Recursive Descent Parsers.
egulias/email-validator 2.1.3 A library for validating emails against several RFCs
erusev/parsedown 1.6.4 Parser for Markdown.
fideloper/proxy 3.3.4 Set trusted proxies for Laravel
filp/whoops 2.1.14 php error handling for cool kids
fzaninotto/faker v1.7.1 Faker is a PHP library that generates fake data for you.
hamcrest/hamcrest-php v1.2.2 This is the PHP port of Hamcrest Matchers
jakub-onderka/php-console-color 0.1
jakub-onderka/php-console-highlighter v0.3.2
laravel/framework v5.5.31 The Laravel Framework.
laravel/tinker v1.0.3 Powerful REPL for the Laravel framework.
league/flysystem 1.0.41 Filesystem abstraction: Many filesystems, one API.
mockery/mockery 0.9.9 Mockery is a simple yet flexible PHP mock object framework for use in unit testing with PHPUnit, PHPSpec or any other testing framework. Its core goal is to offer a test double framew...
monolog/monolog 1.23.0 Sends your logs to files, sockets, inboxes, databases and various web services
mtdowling/cron-expression v1.2.1 CRON for PHP: Calculate the next or previous run date and determine if a CRON expression is due
myclabs/deep-copy 1.7.0 Create deep copies (clones) of your objects
nesbot/carbon 1.22.1 A simple API extension for DateTime.
nikic/php-parser v3.1.3 A PHP parser written in PHP
paragonie/random_compat v2.0.11 PHP 5.x polyfill for random_bytes() and random_int() from PHP 7
phar-io/manifest 1.0.1 Component for reading phar.io manifest information from a PHP Archive (PHAR)
phar-io/version 1.0.1 Library for handling version information and constraints
phpdocumentor/reflection-common 1.0.1 Common reflection classes used by phpdocumentor to reflect the code structure
phpdocumentor/reflection-docblock 4.2.0 With this component, a library can provide support for annotations via DocBlocks or otherwise retrieve information that is embedded in a DocBlock.
phpdocumentor/type-resolver 0.4.0
phpspec/prophecy 1.7.3 Highly opinionated mocking framework for PHP 5.3+
phpunit/php-code-coverage 5.3.0 Library that provides collection, processing, and rendering functionality for PHP code coverage information.
phpunit/php-file-iterator 1.4.5 FilterIterator implementation that filters files based on a list of suffixes.
phpunit/php-text-template 1.2.1 Simple template engine.
phpunit/php-timer 1.0.9 Utility class for timing
phpunit/php-token-stream 2.0.2 Wrapper around PHP's tokenizer extension.
phpunit/phpunit 6.5.5 The PHP Unit Testing framework.
phpunit/phpunit-mock-objects 5.0.6 Mock Object library for PHPUnit
psr/container 1.0.0 Common Container Interface (PHP FIG PSR-11)
psr/http-message 1.0.1 Common interface for HTTP messages
psr/log 1.0.2 Common interface for logging libraries
psr/simple-cache 1.0.0 Common interfaces for simple caching
psy/psysh v0.8.17 An interactive shell for modern PHP.
ramsey/uuid 3.7.2 Formerly rhumsaa/uuid. A PHP 5.4+ library for generating RFC 4122 version 1, 3, 4, and 5 universally unique identifiers (UUID).
sebastian/code-unit-reverse-lookup 1.0.1 Looks up which function or method a line of code belongs to
sebastian/comparator 2.1.2 Provides the functionality to compare PHP values for equality
sebastian/diff 2.0.1 Diff implementation
sebastian/environment 3.1.0 Provides functionality to handle HHVM/PHP environments
sebastian/exporter 3.1.0 Provides the functionality to export PHP variables for visualization
sebastian/global-state 2.0.0 Snapshotting of global state
sebastian/object-enumerator 3.0.3 Traverses array structures and object graphs to enumerate all referenced objects
sebastian/object-reflector 1.1.1 Allows reflection of object attributes, including inherited and non-public ones
sebastian/recursion-context 3.0.0 Provides functionality to recursively process PHP variables
sebastian/resource-operations 1.0.0 Provides a list of PHP built-in functions that operate on resources
sebastian/version 2.0.1 Library that helps with managing the version number of Git-hosted PHP projects
swiftmailer/swiftmailer v6.0.2 Swiftmailer, free feature-rich PHP mailer
symfony/console v3.4.3 Symfony Console Component
symfony/css-selector v3.4.3 Symfony CssSelector Component
symfony/debug v3.4.3 Symfony Debug Component
symfony/event-dispatcher v3.4.3 Symfony EventDispatcher Component
symfony/finder v3.4.3 Symfony Finder Component
symfony/http-foundation v3.4.3 Symfony HttpFoundation Component
symfony/http-kernel v3.4.3 Symfony HttpKernel Component
symfony/polyfill-mbstring v1.6.0 Symfony polyfill for the Mbstring extension
symfony/polyfill-php70 v1.6.0 Symfony polyfill backporting some PHP 7.0+ features to lower PHP versions
symfony/process v3.4.3 Symfony Process Component
symfony/psr-http-message-bridge v1.0.2 PSR HTTP message bridge
symfony/routing v3.4.3 Symfony Routing Component
symfony/translation v3.4.3 Symfony Translation Component
symfony/var-dumper v3.4.3 Symfony mechanism for exploring and dumping PHP variables
theseer/tokenizer 1.1.0 A small library for converting tokenized PHP source code into XML and potentially other formats
tijsverkoyen/css-to-inline-styles 2.2.1 CssToInlineStyles is a class that enables you to convert HTML-pages/files into HTML-pages/files with inline styles. This is very useful when you're sending emails.
vlucas/phpdotenv v2.4.0 Loads environment variables from `.env` to `getenv()`, `$_ENV` and `$_SERVER` automagically.
webmozart/assert 1.2.0 Assertions to validate method input/output with nice error messages.
zendframework/zend-diactoros 1.7.0 PSR HTTP Message implementations
Is this information enough?
phpinfo.zip
(24.18 KiB) Downloaded 798 times
Post by aimeos » 18 Jan 2018, 13:21
Everything looks fine and the x86_64 architecture is the most widely used one.
The only thing you can try is restart from scratch: Delete the whole Laravel application, remove everything related to composer with "composer clearcache". Then start again.
netman2002
Post by netman2002 » 19 Jan 2018, 07:20
Do I need to completely uninstall the composer and related cache data?
Or only I need is to clear full cache of composer?
