Basket standard Problem
tenkraD
Post by tenkraD » 30 Jan 2018, 16:23
Hi again,
i try to display the standard basket if i click on buy on the detail side.
So for this i changed the plugin from mini basket to standard basket.
Now i should see in the basket the products other users bought with, but it dosn't work.
I just see the mini basket.
How can i do that? Do i misunderstood something?
Typo3 7.6.x / Aimeos 17.10.0
Many Thanks
Re: Basket standard Problem
Post by aimeos » 30 Jan 2018, 18:10
If you put something into the basket, the standard basket is loaded from the basket page via AJAX and only that part is displayed - regardless of the basket related plugin that may be also on this page. You can change that behavior if you overwrite the JS method to jump to the basket page directly:
https://github.com/aimeos/ai-client-htm ... os.js#L533
