Cant set setting catalog tree levels-always in template
tenkraD
Post by tenkraD » 01 Feb 2018, 16:54
I want to show 3 levels of my catalog as default.
client/html/catalog/filter/tree/levels-always =
So i tried to set plugin.tx_aimeos.settings.client.html.catalog.filter.tree.levels-always = 3 in my template under page section", but i doesn't work.
If i set the same code on the plugin in the section typoscript configuration - It works.
If i set it on the plugin in the field show al categories until - It works also.
Cant this be done in the template or do i something wrong?
Typo3 7.6.20 / Aimeos 17.10.0
Re: Cant set setting catalog tree levels-always in template
Post by aimeos » 02 Feb 2018, 17:49
That's a problem in TYPO3: You have to set level-always in the Flexform of the plugin. Otherwise, TYPO3 overwrites your setup TS setting with the empty value from that Flexform.
