Multiple Sites
tenkraD
Multiple Sites
Post by tenkraD » 21 Feb 2018, 13:44
I created an second site.
https://aimeos.org/docs/User_Manual/Adm ... with_sites
My Problem is that i cant see the site changer in normal modus.
In the expert modus i see the site changer and can use it but in normal modus i am unable to select my second site.
What can i do to see the site changer in normal modus? Thanks.
Typo3 7.6.x / Aimeos 17.10.0
How it is on expert modus
Expert Modus.JPG (15.34 KiB) Viewed 5157 times
How it is on normal modus
Normal Modus.JPG (16.17 KiB) Viewed 5157 times
How it should be on normal modus
Re: Multiple Sites
Post by aimeos » 21 Feb 2018, 22:45
In 2017.10 you can't change between all sites in the simple admin interface because your user only has rights for one site. In the latest dev-master branch it's possible to change between all sites if your user has super user privileges.
tenkraD
Re: Multiple Sites
Post by tenkraD » 01 Apr 2018, 10:52
I installed now aimeos 18.1.1 and like before i cannot switch between multiple sites...
Re: Multiple Sites
Post by aimeos » 03 Apr 2018, 07:45
There was a bug in the page template that renders the sidebar:
https://github.com/aimeos/ai-admin-jqad ... 0e78fcdeec
The fix will be included in the upcoming 18.4.0 release.
