Order History via the API
ntnsapre
Post by ntnsapre » 23 Feb 2018, 07:18
Is there a way to get the logged in user's order history via the JSON API? I can't see to find this via the methods available.
Re: Order History via the API
Post by aimeos » 23 Feb 2018, 23:11
You can use a GET request to the "order" endpoint to get the orders of the currently logged in customer:
https://aimeos.org/docs/Developers/Clie ... e_metadata
What you currently can't fetch using that endpoint are the order details.
ntnsapre
Post by ntnsapre » 24 Feb 2018, 13:38
All right, thank you!
