Aimeos TYPO3 Frontend Login CSS Changes
markusreisinger
I wanted to move the login form from the current position to the new position between the two red lines as you see on the picture, but I cannot find the right CSS to change this. Maybe I can change it somewhere else? I think it should work with padding but as I said I cannot find the right file to change it. Can you tell my which file I have to change?
TYPO3 8.7.8
PHP Version 7.1.9
Aimeos 17.10.1
bootstrap_package 8.0.4
TYPO3 8.7.8
PHP Version 7.1.9
Aimeos 17.10.1
- abc.jpg (216.22 KiB) Viewed 3032 times
Re: Aimeos TYPO3 Frontend Login CSS Changes
You can use the Bootstrap grid system to position the login form like you want
