Laravel Aimeos Extension Stopped Existing Functionality
mohal_04
Post by mohal_04 » 04 Apr 2018, 06:53
I have been trying to add a new field in Product form. For which I have been asking help on this post: post5892.html#p5892
But the funny thing happened is that now existing fields are not saving data in sub-part.
The field I added is "oldcode." I have added it in Basic section can be seen in this screen-shot:
But now fields on other sections are not working. For example, images are not saving now and Texts are also not saving. Plus, price is also not saving. See attached screen-shot:
Do I have to overwrite all these fields? If yes then how?
Please, reply!
Thanks!
mohal_04
Re: Laravel Aimeos Extension Stopped Existing Functionality
Post by mohal_04 » 04 Apr 2018, 08:01
mohal_04 wrote:Hi,
But now fields on other sections are not working. For example, images are being saved but not shown and Texts are also not showing. Plus, price is also not showing. See attached screen-shot:
Please, reply!
Thanks!
Post by aimeos » 04 Apr 2018, 22:02
No, you don't have to overwrite something else. If the data isn't saved, either an exception occured or the transaction failed and your changes are rolled back.
mohal_04
Post by mohal_04 » 05 Apr 2018, 06:26
Thanks to great @aimeos support.
I have solved my issue with the help from @aimeos ...
post5955.html#p5955
