Free delivery, when ordering for more then x €
chricken
Post by chricken » 04 Apr 2018, 13:51
Hi, there is one issue with my shop, I still haven't solved, yet.
When a customer is ordering for more then 100€, there should be no delivery costs.
I am pretty sure, that is easy to achive, can anyone give me a hint?
Regards
Christian
Re: Free delivery, when ordering for more then x €
Post by aimeos » 04 Apr 2018, 22:08
chricken
Post by chricken » 12 Apr 2018, 11:29
Okay,
thanks for answering.
It works, but I have a few issues with it:
  • - The transportation price is no more shown in the overview. That may cause some struggle.
    - When the customers selects the transportation, the costs are shown with full price.
So the customer is somewhat irritated, if and how much he has to pay.
I am running v17.10.2, has there been any change in that behaviour?
Regsrads
Christian
Post by aimeos » 13 Apr 2018, 17:34
For the first problem, you can change that if you overwrite the detail template and remove the if() here:
https://github.com/aimeos/ai-client-htm ... d.php#L375
To prevent the second problem, you can add the "Reduction" decorator to your delivery options with 100% reduction over e.g. 100€:
https://aimeos.org/docs/User_Manual/Adm ... #Reduction
