Aimeos + postgresql: boolean column type problem
etienne.bonnin
Post by etienne.bonnin » 30 May 2018, 18:15
I followed the default aimeos symfony bundle installation.
Symfony version 3.4.11
Aimeos version: 2018.04
My config.yml is:
fos_user:
    db_driver: orm
    firewall_name: main
    user_class: AppBundle\Entity\User
    from_email:
        address: email@mycompany.zzz
        sender_name: 'My sender name'
doctrine:
    dbal:
        driver: %database_driver%
        host: '%database_host%'
        port: '%database_port%'
        dbname: '%database_name%'
        user: '%database_user%'
        password: '%database_password%'
        charset: UTF8
    orm:
        auto_generate_proxy_classes: '%kernel.debug%'
        naming_strategy: doctrine.orm.naming_strategy.underscore
        auto_mapping: true
aimeos_shop:
    mshop:
        customer:
            manager:
                password:
    resource:
            db:
                adapter: pgsql
                host: %database_host%
                port: %database_port%
                database: %database_name%
                username: %database_user%
                password: %database_password%
                stmt: null
                #stmt: ["SET NAMES 'utf8'", "SET SESSION sql_mode='ANSI'"]
                #limit: 2
                #opt-persistent: 0
But when I want add admin user:
php bin/console aimeos:account --admin email@mycompany.zzz
I obtain the following error:
red@barbalbero:~/symfony/ecommerce$ php bin/console aimeos:account --admin email@mycompany.zzz
Password
In Simple.php line 97:
  An exception occurred while executing '
  					INSERT INTO "fos_user" (
  						"siteid", "username_canonical", "username", "company", "vatid", "salutation", "title",
  						"firstname", "lastname", "address1", "address2", "address3",
  						"postal", "city", "state", "countryid", "langid", "telephone",
  						"email_canonical", "email", "telefax", "website", "longitude", "latitude",
  						"birthday", "enabled", "vdate", "password", "mtime", "editor", "roles", "salt",
  						"ctime"
  					) VALUES (
  						1,'email@mycompany.zzz','email@mycompany.zzz','','','','','','','','','','','','',NULL,NULL,'','email@mycompany.zzz','email@mycompany.zzz','','',NULL,NULL,NULL,1,NULL,'$2y$
  10$XZUZul7qxTYvRgdyXcBJ8.B0InI2ujAHtmu//pogU96BCA8sgApzO','2018-05-30 19:57:40','aimeos:account','a:0:{}','','2018-05-30 19:57:40'
  SQLSTATE[42804]: Datatype mismatch: 7 ERROR:  column "enabled" is of type boolean but expression is of type integer
  LINE 10: ...y.zzz','email@mycompany.zzz','','',NULL,NULL,NULL,1,NULL,'$2...
  HINT:  You will need to rewrite or cast the expression.
The same error occours when the initial process try to add demo data into the "fos_user" table (for the same field, enabled::boolean).
It seems a mysql vs postgresql compatibility problem. Did I forget something in doctrine configuration?
Thanks in advance
Re: Aimeos + postgresql: boolean column type problem
Post by aimeos » 31 May 2018, 21:16
You are right, this seems like a compatibility problem because for PostgreSQL "1" isn't the same as "true"
Post by aimeos » 31 May 2018, 21:40
Changed the code in dev-master so it stores a true/false value now:
https://github.com/aimeos/ai-fosuser/co ... 490af50f07
Can you check if it works in your environment too? Then, we can make a new 2018.04.x release.
etienne.bonnin
Post by etienne.bonnin » 04 Jun 2018, 09:24
Sorry but the patch you provided doesn't work in my environment. It seems that "true" value is translated to "1" and "false" to "0" in the bind (?) method. The error is the same.
etienne.bonnin
Post by etienne.bonnin » 04 Jun 2018, 09:43
I found a temporary solution in:
vendor/aimeos/aimeos-core/lib/mwlib/src/MW/DB/Statement/DBAL/Simple.php
59c59
< 				$this->binds[$position] = (int) (bool) $value; break;
> 				$this->binds[$position] = ((bool) $value)?"true":"false"; break;
Hope this helps!
Post by aimeos » 05 Jun 2018, 07:09
Yes, that was really helpful! :-)
We've integrated your fix and released a new version (core: 2018.04.7, ai-fosuser: 2018.04.2). Now it should work flawlessly with the FOSUser bundle and PostgreSQL.
