Basket Plugin Log Decorator
sixbynine
Post by sixbynine » 11 Jul 2018, 11:05
I read in the documentation :
Since 2015.06, you can log plug-in activities using the "Log" decorator when you need to debug your code, so you will be able to retrace the actions in the log entries.
I just wonder where are located the logs of the "Log" decorator.
I'm using Laravel, it doesn't seem to be in the laravel.log
Thank you very much !
Re: Basket Plugin Log Decorator
Post by aimeos » 12 Jul 2018, 11:54
You can find it in the Log panel of the admin interface
