error with helper {{ url('/') }}
h2jose
Hi, i have problem with breadcrumb home link and logo link to return home when the detail is shown.
I found the helper in the line 104 at "ext/ai-client-html/client/html/templates/catalog/detail/body-standard.php", i think the helper required blade template file instead (body-standard.blade.php).
I used, now work fine.
I found the helper
href="{{ url('/') }}I used
href="<?= url('/') ?>"Re: error with helper {{ url('/') }}
Can you please give us a link to the line on GitHub? https://github.com/aimeos/ai-client-html
We can't find such a line in the mentioned file.
