Error installing demo data on laravel package 2018.07
ajrmzcs
Post by ajrmzcs » 18 Jul 2018, 21:08
Hi, following the installation steps found this error when running: php artisan aimeos:setup --option=setup/default/demo:1
Screenshot from 2018-07-18 16-04-11.png (75.82 KiB) Viewed 5560 times
Please help,
Thanks...
Re: Error installing demo data on laravel package 2018.07
Post by aimeos » 19 Jul 2018, 10:07
Maybe this is a follow up problem of what you've described here:
laravel-package-f18/upgrading-aimeos-fr ... t1516.html
ajrmzcs
Post by ajrmzcs » 19 Jul 2018, 14:24
Thank you for your response,
However, even when problems can be related as you mentioned... I tried to install aimeos/laravel 2018.07 in a brand new laravel 5.6 installation with the ai-payment module and still getting this same error:
RuntimeException : No product for code "demo-article" found
at /home/antonio/aimeos201804/vendor/aimeos/aimeos-core/lib/mshoplib/setup/MShopAddDataAbstract.php:378
Thanks,
Post by aimeos » 21 Jul 2018, 08:09
Can you post the complete output of the exception and the lines that have been outputed before?
ajrmzcs
Post by ajrmzcs » 26 Jul 2018, 14:36
Hi, the response is the image attached on the first thread.
Regards.
Post by aimeos » 26 Jul 2018, 21:31
That's not enough to getting closer to the problem. We need the full output of
