Product downloads section not working
michal.fehér
Post by michal.fehér » 31 Jul 2018, 08:37
Hi. I think there is a bug in adding files to product.
When I upload a file from admin, it gets stored to product_list as hidden attribute.
In body-standard.php you call it this way
$this->detailProductItem->getRefItems( 'media', null, 'download' )
which returns an empty array.
And BTW, how can I remove uploaded file? Or add more than 1 file?
Thanks.
Re: Product downloads section not working
Post by aimeos » 01 Aug 2018, 10:09
You mix up two things:
- Public file downloads must be added in the "Images" tab with type "download"
- Files that are delivered to the customers once they bought the product must be added in the "Download" tab
michal.fehér
Post by michal.fehér » 01 Aug 2018, 12:00
OK, now I see it. not the best naming then though.
One more question. why previews are only working with images? it's a broken image when I upload PDF or doc.
<img class="media-image" src="http://damito.test/packages/aimeos/shop ... cument.png" alt="2018.05.18_CReg_ziadost.docx">
Post by aimeos » 01 Aug 2018, 13:41
What naming for files that are sold would you suggest?
There aren't icons for all mime types available (but application/pdf.png is). You should add icons for the mime types you are using and which are missing to the directory.
