Extend translation class
Sergunik
Post by Sergunik » 09 Aug 2018, 12:49
Main issue:
Detect all not translated phrases in project.
Idea:
Replace or extend function aitrans.
My extended function should consist of parent functionality and few extra (dirty) rows:
IF (phrase has no translation) THEN log this phrase to file
After that need only surf cross the website.
First problem:
aitrans – it's not a function of class. It's only helper. So decided to extend function dt - main functionality from aitrans.
Second problem:
Function dt related to different classes.
Which one need to use and where in project should I place replacement?
Laravel: 5.5,
Aimeos: 2018.07,
PHP: 7.0,
Linux
Re: Extend translation class
Post by aimeos » 10 Aug 2018, 18:59
OUr suggestion would be to write a simple translation decorator that checks $input === $output:
https://github.com/aimeos/aimeos-core/t ... /Decorator
You can add it for tests here:
https://github.com/aimeos/aimeos-larave ... 8n.php#L56
You will get only missing frontend translations and probably almost no errors. In the end, you should fully translate Aimeos to your language: https://www.transifex.com/aimeos/public/ :-)
