Disable service, basket plugin for JSONAPI only
sixbynine
Post by sixbynine » 10 Aug 2018, 06:21
Is there a way to disable a given service or basket plugin only for JSONAPI?
Thank you a lot in advance,
sbn
Re: Disable service, basket plugin for JSONAPI only
Post by aimeos » 10 Aug 2018, 12:35
Not in the standard code base. You need to install the ai-sites extension from the Aimeos company and create two sub-sites, one for the HTML frontend and one for the JSONAPI. Then you can configure different services for both sites:
https://aimeos.com/extensions/#c1331
