Extend Files
jramirezgranada
Extend Files
Post by jramirezgranada » 16 Aug 2018, 21:21
How can I extend ext/ai-client-html/client/html/src/Client/Html/Basket/Standard/Standard.php int my own extension ?
I created the file in the same folder structure ext/myext/client/html/src/Client/Html/Basket/Standard/MyExtStandard.php but it doesn't work.
Do i have to setup it in any config file ?
Jorge A Ramirez
System Engineer
PHP Developer
Re: Extend Files
Post by aimeos » 17 Aug 2018, 17:56
Yes, you need to configure the name of your new class so it's used instead of the Standard one:
https://aimeos.org/docs/Configuration/C ... ndard/name
