Coupon Configuration
Seds
Post by Seds » 27 Aug 2018, 11:45
What are requirements for coupon ?
I just want a reduce coupon of 10€ for example
Because i have this message in basket:
Requirements for coupon code "XXX" aren't met
how it works?
Re: Coupon Configuration
Post by aimeos » 29 Aug 2018, 21:48
If you use the coupon configuration from the demo setup, remove the decorators from the "provider" field (everything starting from the comma and beyond). Then, you will have no restrictions
