Problems installing & Running Aimeos locally
granola
Post by granola » 04 Sep 2018, 06:14
Hello
Am a Laravel Noob so apologies in advance! :-)
Just installed from https://packagist.org/packages/aimeos/aimeos
Followed the Readme.
Created a mysql db called "granola".
Served the site on 8080 as have other project running on 8000.
Got the following error message, when i try and view the project on: http://127.0.0.1:8080/list
An exception occurred while executing ' SELECT mlocsi."id" AS "locale.site.id", mlocsi."code" AS "locale.site.code", mlocsi."label" AS "locale.site.label", mlocsi."config" AS "locale.site.config", mlocsi."status" AS "locale.site.status", mlocsi."editor" AS "locale.site.editor", mlocsi."mtime" AS "locale.site.mtime", mlocsi."ctime" AS "locale.site.ctime" FROM "mshop_locale_site" AS mlocsi WHERE mlocsi."level" = 0 AND mlocsi."code" = 'default' GROUP BY mlocsi."id", mlocsi."code", mlocsi."label", mlocsi."config", mlocsi."status", mlocsi."editor", mlocsi."mtime", mlocsi."ctime" ORDER BY mlocsi."id" ASC LIMIT 100 OFFSET 0 ': SQLSTATE[42S02]: Base table or view not found: 1146 Table 'granola.mshop_locale_site' doesn't exist
granola
Re: Problems installing & Running Aimeos locally
Post by granola » 05 Sep 2018, 03:33
OK, have somehow managed to get it working myself (not through any skill). The instructions in the reaad.me are not very clear for a noob. Would it be possible to revisit them with a novices eye and add in basic instructions/details that experienced users assume everybody knows. Tks :)
Post by aimeos » 05 Sep 2018, 09:40
There's not much you can do wrong besides using wrong database credentials
Post by aimeos » 05 Sep 2018, 09:43
Can you post the complete output when running
composer create-project aimeos/aimeos myshop
