Is it possible to have decimal values for product quantity
madasha
Post by madasha » 09 Sep 2018, 21:24
Hello, I am using Aimeos for Laravel for the past 6 months or so and I find it great. I only have one problem that I am trying to find a solution for: I'd like to sell stuff that is sold in kilos, meaning that people might want to buy fractions, instead of whole numbers, e.g.: 1.2 kg of pale ale malt.
My question is: Is there an efficient way (without having to make a lot of changes to underlying DB and related models) to make product quantities work with fractions/decimals and be able to purchase for example 2.4 of something.
I hope I made myself clear, if not, please let me know, so that I can clarify the question further.
David Haška
Re: Is it possible to have decimal values for product quanti
Post by David Haška » 11 Sep 2018, 17:00
I also want to know that. Could anyone please answer this question? Thank you so much :))
Post by aimeos » 11 Sep 2018, 20:10
Not yet. You have to change the column definition in the mshop_order_base_product table and adapt the item. Would be great if you create a pull request so we can merge it into the core :-)
