how to change the context in *.po file and make it works
劉建德
Post by 劉建德 » 15 Sep 2018, 08:36
hi, there,
I'm a developer form asian,
and I have found some context in Chinese incorrect there in Admin panel, frontend.
how do I correct it and make it works?
I have try to edit *.po file by Poedit then clear cache,
but it seems to no works, how should I do ?
Re: how to change the context in *.po file and make it works
Post by aimeos » 15 Sep 2018, 09:12
You should register at Transifex and adapt the translations there:
https://www.transifex.com/aimeos/public/
Your changes will be automatically added to the next Aimeos release.
劉建德
Post by 劉建德 » 17 Sep 2018, 07:55
thanks, and the orther question is,
how do I correct the content on my site ?
Post by aimeos » 18 Sep 2018, 11:44
Like said, your translation changes in Transifex will be automatically integrated into the next (minor) release.
If you want to replace existing translations with project-specific translations, you can overwrite them
- in your config if they are only a few ones (e.g https://aimeos.org/docs/Laravel/Overwrite_translations)
- in your extension (https://aimeos.org/docs/Developers/Add_translations)
