New admin tab for shop configuration
David Haška
Post by David Haška » 26 Sep 2018, 12:13
is there any solution to make a new tab with shop configuration - sub-tabs will be modules / extensions.
For example we want to have dynamic banners (we will change them every week) - best as module / extension. We want to edit / reupload them in current admin page and we want some configuration to be set in this "TAB".. Do you know how to implement that?
Currently we solved this with different admin in Laravel - it has different URL (not /admin but /adminext) but we dont want to have two different admin pages.
Re: New admin tab for shop configuration
Post by aimeos » 27 Sep 2018, 14:07
Sure, you can extend the administration interface by new panels but there is no documentation for that yet.
The steps are in your own extension:
- Create a new Admin/JQAdm/ class like the existing ones
- Add list and item templates for your class
- You can add CSS/JS code in the files in the themes folder
- Configure the navbar to include your new panel (https://github.com/aimeos/ai-admin-jqad ... navbar.php
- If you have subpanels then configure them too (https://github.com/aimeos/ai-admin-jqad ... /admin.php)
- Configure the permissions for your new panel (https://github.com/aimeos/ai-admin-jqad ... source.php)
