User Address - Checkout Process
jramirezgranada
Post by jramirezgranada » 08 Oct 2018, 20:08
Hi there;
I'm working in a some feature in the checkout process
I saw this code in the address-delivery-body-standard.php
<?php foreach ($this->get('addressDeliveryItems', []) as $id => $addr) : ?>
<?php endoreach; ?>
I supposed that that block code load the addresses stored in the users_address table.
Now, I checked Aimeos\Client\Html\Checkout\Standard\Address\Delivery\Standard.php in addData method this.
        $controller = \Aimeos\Controller\Frontend\Factory::createController($context, 'customer');
        $orderAddressManager = \Aimeos\MShop\Factory::createManager($context, 'order/base/address');
        try {
            $deliveryAddressItems = [];
            $item = $controller->getItem($context->getUserId(), ['address']);
            foreach ($item->getAddressItems() as $id => $addrItem) {
                $deliveryAddressItems[$id] = $orderAddressManager->createItem()->copyFrom($addrItem);
            $paymentAddressItem = $orderAddressManager->createItem()->copyFrom($item->getPaymentAddress());
            $view->addressCustomerItem = $item;
            $view->addressPaymentItem = $paymentAddressItem;
            $view->addressDeliveryItems = $deliveryAddressItems;
        } catch (\Exception $e) {
        } // customer has no account yet
But the $deliveryAddressItems array always is empty, is there something i need to do ?
Jorge A Ramirez
System Engineer
PHP Developer
mohal_04
Re: User Address - Checkout Process
Post by mohal_04 » 09 Oct 2018, 17:27
jramirezgranada wrote:Hi there;
<?php endoreach; ?>
        try {
Are you working on the page where user enters its addressess?
Thanks!
jramirezgranada
Post by jramirezgranada » 09 Oct 2018, 19:46
Yes, in the checkout process.
I found a bug there, in the Aimeos\Client\Html\Checkout\Standard\Address\Delivery\Standard.php in this line aimeos needs to change this $item = $controller->getItem($context->getUserId(), ['address']); to this $item = $controller->getItem($context->getUserId(), ['customer/address']);
Jorge A Ramirez
System Engineer
PHP Developer
Post by aimeos » 09 Oct 2018, 19:59
The bug should have been fixed in the new 2018.10 version released today. Could you check that please?
