Error saving characteristics attributes
jramirezgranada
Post by jramirezgranada » 18 Oct 2018, 16:41
Hi there;
When I'm saving a product with multiple attributes with the same attribute type I'm getting this error:
An exception occurred while executing '\n
\t\t\t\t\t\tSELECT msupli."id" AS "supplier.lists.id", msupli."parentid" AS "supplier.lists.parentid",\n
\t\t\t\t\t\t\tmsupli."siteid" AS "supplier.lists.siteid", msupli."typeid" AS "supplier.lists.typeid",\n
\t\t\t\t\t\t\tmsupli."domain" AS "supplier.lists.domain", msupli."refid" AS "supplier.lists.refid",\n
\t\t\t\t\t\t\tmsupli."start" AS "supplier.lists.datestart", msupli."end" AS "supplier.lists.dateend",\n
\t\t\t\t\t\t\tmsupli."config" AS "supplier.lists.config", msupli."pos" AS "supplier.lists.position",\n
\t\t\t\t\t\t\tmsupli."status" AS "supplier.lists.status", msupli."mtime" AS "supplier.lists.mtime",\n
\t\t\t\t\t\t\tmsupli."editor" AS "supplier.lists.editor", msupli."ctime" AS "supplier.lists.ctime"\n
\t\t\t\t\t\tFROM "mshop_supplier_list" AS msupli\n
\t\t\t\t\t\t\n
\t\t\t\t\t\tWHERE ( msupli."siteid" IN (1) AND ( msupli."refid" IN ('1') AND msupli."domain" = 'product' AND ( msupli."status" = 1 AND ( msupli."start" <= '2018 ▶
\t\t\t\t\t\tGROUP BY msupli."id", msupli."parentid", msupli."siteid", msupli."typeid",\n
\t\t\t\t\t\t\tmsupli."domain", msupli."refid", msupli."start", msupli."end",\n
\t\t\t\t\t\t\tmsupli."config", msupli."pos", msupli."status", msupli."mtime",\n
\t\t\t\t\t\t\tmsupli."editor", msupli."ctime" \n
\t\t\t\t\t\t\n
\t\t\t\t\t\tLIMIT 2147483647 OFFSET 0\n
\t\t\t\t\t':\n
\n
SQLSTATE[25P02]: In failed sql transaction: 7 ERROR:  current transaction is aborted, commands ignored until end of transaction block
Any idea or help ?
Jorge A Ramirez
System Engineer
PHP Developer
jramirezgranada
Re: Error saving characteristics attributes
Post by jramirezgranada » 18 Oct 2018, 20:28
I noticed this:
I have this attribute:
Note: If I try to save this attribute i got the above error.
typeid: 125
siteid: 1
domain: product
code: www.company.com/path/anthony-mancuso.html
label: Anthony Mancuso
pos: 4
status: 1
mtime: 2018-10-18 08:28:47
ctime: 2018-10-18 08:28:47
Also I have this one:
Note: If I try to save with this attribute I don't get the error
type id: 125
siteid: 1
domain: product
code: amy-delpo.html
label: Amy DelPo
pos:3
status: 1
mtime: 2018-10-18 13:19:07
Notice that both have the same type id
Jorge A Ramirez
System Engineer
PHP Developer
Post by aimeos » 21 Oct 2018, 12:17
How long is the VARCHAR column of mshop_attribute.code in your database? It should be 255 characters:
https://github.com/aimeos/aimeos-core/b ... te.php#L43
jramirezgranada
Post by jramirezgranada » 21 Oct 2018, 16:21
Yes, but the code in the mshop_index_attribute is 32 characters. That does not make sense. It is breaking up the data integrity.
Jorge A Ramirez
System Engineer
PHP Developer
Post by aimeos » 21 Oct 2018, 18:34
You are right. It has been fixed in dev-master and 2018.10 branch. You can test by adding this to the "require" section of your composer.json file:
"aimeos/aimeos-core": "2018.10.x-dev"
Then execute this to update the table:
./artisan aimeos:setup
