Scale Image
jramirezgranada
Scale Image
Post by jramirezgranada » 07 Nov 2018, 18:20
Hi there;
I'm extending namespace Aimeos\Controller\Common\Media\Standard controller to add more images like a thumbnail using the original image.
The process is working good, but the new image is't good, it doesn't have a good proportion and it's pixeled.
Look the original image,
And the scaled image
is there a way to keep the resolution,
This is my configuration
'common' => [
        'media' => [
            'name' => 'MyStandard',
            'standard' => [
                'thumbnail' => [
                    'maxwidth' => 60,
                    'maxheight' => 78
                'small_image' => [
                    'maxwidth' => 80,
                    'maxheight' => 104
                'options' => [
                    'image' => [
                        'name' => 'Imagick',
                        'quality' => 100
Jorge A Ramirez
System Engineer
PHP Developer
Re: Scale Image
Post by aimeos » 08 Jul 2019, 11:05
The new Aimeos 2019.07 now contains code to generate responsive images automatically (sizes are configurable)
