Payment Gateway
cs42na
Payment Gateway
Post by cs42na » 19 Nov 2018, 15:10
Hello , I have problem implementin a new omnipay payment method. I have imported the ai-payments extension and the omnipay package. I have also imported the omnipay gateway package of my provider (2checkout). I have created a new payment service with omnipay.type = "2Checkout" . When i select the payment method during checkout, and proceed to make the payment , I am getting the error message "/Omnipay/2Checkout/Gateway class not found/" . What else does it needs to be implement as the documentation is not quite clear.
Re: Payment Gateway
Post by aimeos » 21 Nov 2018, 09:27
Do you use this one?
https://github.com/collizo4sky/omnipay-2checkout
The old driver is deprecated. With that one, "omnipay.type" should be "TwoCheckoutPlus" and you need to set parameters for "accountNumber" and "secretWord" in the Aimeos admin interface.
