Taskerror from daily task
kranzfr3d
Post by kranzfr3d » 23 Nov 2018, 15:10
after following this guide one task is failing with the following error:
Execution failed: 0, Required configuration for "controller/jobs/catalog/import/csv/location" is missing
The other tasks in scheduler are working well.
Kindly provide me the solution where/how to configure this to get rid of the failure
gr33tz
Re: Taskerror from daily task
Post by aimeos » 26 Nov 2018, 10:38
Either you have to configure a directory where the catalog CSV files for the import are located (using controller.jobs.catalog.import.csv.location = /path/to/directory/ in the TS-Config field) or you remove the job if you don't need it
kranzfr3d
Post by kranzfr3d » 26 Nov 2018, 12:57
thanks a lot to get started with jobs.
Had to create the following lines in TS of that job:
controller.jobs.catalog.import.csv.location = /var/www/html/typo3conf/ext/aimeos/Configuration/catalog_import_csv
controller.jobs.product.export.sitemap.location = /var/www/html/typo3conf/ext/aimeos/Configuration/sitemap
controller.jobs.product.import.csv.location = /var/www/html/typo3conf/ext/aimeos/Configuration/product_import_csv
That paths / folders were first created to get the job working.
Could you please tell me where the folders are best kept in each case?
gr33tz
Post by aimeos » 27 Nov 2018, 13:38
The sitemap.xml should be placed in the document root or your vhost or in the typo3temp directory if your document root shouldn't be writable.
The directories for the product/catalog CSV files should be placed OUTSIDE of the document root so nobody can download them if he knows their names. If that's not possible, they should be in ./fileadmin/.secure/ (or another directory starting with a dot in the name) because these directories are blocked by the default rewrite rules in the .htaccess file.
kranzfr3d
Post by kranzfr3d » 27 Nov 2018, 20:49
ok, thank you very much for the locations.
My folders are here now:
controller.jobs.catalog.import.csv.location = /var/www/aimeos_catalog_import_csv
controller.jobs.product.import.csv.location = /var/www/aimeos_product_import_csv
Are they ok now?
gr33tz
