Site for code "default" not found after fresh install
Doglexx
Post by Doglexx » 02 Dec 2018, 11:50
Good day!
First of all, I'd like to give thanks to all the Aimeos contributors for support of this project.
To test Aimeos, I performed actions from Installation paragraph described here: https://github.com/aimeos/aimeos.
I was asked for DB, SMTP and admin credentials and had no errors.
When I navigated to the subdomain, where the project was installed I got "Site for code "default" not found" Exception raised on line 129 of /vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Locale/Manager/Standard.php.
        if( ( $siteItem = reset( $siteItems ) ) === false ) {
            throw new \Aimeos\MShop\Locale\Exception( sprintf( 'Site for code "%1$s" not found', $site ) );
I searched for possible issues and run
./artisan aimeos:setup --option=setup/default/demo:1
, but had no success.
My server conf:
Ubuntu 16.04.4 LTS
Apache/2.4.18
PHP 7.0.28-0
MySQL 5.7.22
I was able to login to /admin page, but it shows only:
Dashboard
You are logged in!
in the center and drop-down in the upper-right corner with the only option "Logout".
Any ideas what I've missed?
Re: Site for code "default" not found after fresh install
Post by aimeos » 02 Dec 2018, 13:46
There seem to be some problems with packagist:
Failed to download aimeos/aimeos-core from dist: Invalid credentials for 'https://packages.aimeos.org/aimeos/dist/aimeos/aimeos-core/aimeos-aimeos-core-e7a9fffbab58d8926065d7c8b51b0bbecd81482e-zip-1c6be3.zip', aborting.
Did you see something similar during downloading of the packages?
Doglexx
Post by Doglexx » 02 Dec 2018, 15:23
aimeos wrote:There seem to be some problems with packagist:
I still have my terminal opened with all the history so:
0 results for "Failed to download"
Results for "aimeos-core":
 - Installing aimeos/aimeos-core (2017.10.15): Downloading (100%)
aimeos/aimeos-core suggests installing apigen/apigen (Required for generating the API documentation)
I used this command to create-project
$ composer create-project aimeos/aimeos .
Installing aimeos/aimeos (2017.10.4)
  - Installing aimeos/aimeos (2017.10.4): Downloading (100%)
Created project in .
<list of installed packages>
Post by aimeos » 03 Dec 2018, 12:56
Can you have a look into the mshop_locale_site and mshop_locale tables if there are entries and if they have a status of "1"?
We've installed the Aimeos application from scratch and it worked out of the box:
composer create-project aimeos/aimeos aimeos
If it doesn't work for you, can you install from scratch again and post the lengthy output of the installation process (without the passwords)?
Doglexx
Post by Doglexx » 04 Dec 2018, 20:20
Same result.
mshop_locale:
mshop_locale_site:
Composer version 1.7.3 2018-11-01 10:05:06.
Installation log ()
$ composer create-project aimeos/aimeos aimeos.example.com/
  - Installing aimeos/aimeos (2017.10.4): Loading from cache
Created project in aimeos.example.com/
> @php -r "file_exists('.env') || copy('.env.example', '.env');"
> @php -r "mkdir('public/files'); mkdir('public/preview'); mkdir('public/uploads');"
Loading composer repositories with package information
Updating dependencies (including require-dev)
Package operations: 91 installs, 0 updates, 0 removals
  - Installing composer/installers (v1.6.0): Loading from cache
  - Installing vlucas/phpdotenv (v2.5.1): Loading from cache
  - Installing symfony/css-selector (v3.4.19): Loading from cache
  - Installing tijsverkoyen/css-to-inline-styles (2.2.1): Loading from cache
  - Installing symfony/polyfill-mbstring (v1.10.0): Loading from cache
  - Installing symfony/var-dumper (v3.4.19): Loading from cache
  - Installing symfony/routing (v3.4.19): Loading from cache
  - Installing symfony/process (v3.4.19): Loading from cache
  - Installing paragonie/random_compat (v9.99.99): Loading from cache
  - Installing symfony/polyfill-php70 (v1.10.0): Loading from cache
  - Installing symfony/http-foundation (v3.4.19): Loading from cache
  - Installing symfony/event-dispatcher (v3.4.19): Loading from cache
  - Installing psr/log (1.1.0): Loading from cache
  - Installing symfony/debug (v3.4.19): Loading from cache
  - Installing symfony/polyfill-ctype (v1.10.0): Loading from cache
  - Installing symfony/http-kernel (v3.4.19): Loading from cache
  - Installing symfony/finder (v3.4.19): Loading from cache
  - Installing symfony/console (v3.4.19): Loading from cache
  - Installing doctrine/lexer (v1.0.1): Loading from cache
  - Installing egulias/email-validator (2.1.6): Loading from cache
  - Installing swiftmailer/swiftmailer (v6.1.3): Loading from cache
  - Installing ramsey/uuid (3.8.0): Loading from cache
  - Installing psr/simple-cache (1.0.1): Loading from cache
  - Installing psr/container (1.0.0): Loading from cache
  - Installing symfony/translation (v3.4.19): Loading from cache
  - Installing nesbot/carbon (1.36.1): Loading from cache
  - Installing mtdowling/cron-expression (v1.2.1): Loading from cache
  - Installing monolog/monolog (1.24.0): Loading from cache
  - Installing league/flysystem (1.0.49): Loading from cache
  - Installing erusev/parsedown (1.7.1): Loading from cache
  - Installing doctrine/inflector (v1.2.0): Loading from cache
  - Installing laravel/framework (v5.5.44): Loading from cache
  - Installing psr/http-message (1.0.1): Loading from cache
  - Installing zendframework/zend-diactoros (1.8.6): Loading from cache
  - Installing jakub-onderka/php-console-color (v0.2): Loading from cache
  - Installing dnoegel/php-xdg-base-dir (0.1): Loading from cache
  - Installing nikic/php-parser (v4.1.0): Loading from cache
  - Installing fideloper/proxy (3.3.4): Loading from cache
  - Installing jakub-onderka/php-console-highlighter (v0.4): Loading from cache
  - Installing psy/psysh (v0.9.9): Loading from cache
  - Installing laravel/tinker (v1.0.8): Loading from cache
  - Installing doctrine/cache (v1.6.2): Loading from cache
  - Installing doctrine/annotations (v1.4.0): Loading from cache
  - Installing doctrine/collections (v1.4.0): Loading from cache
  - Installing doctrine/common (v2.7.3): Loading from cache
  - Installing doctrine/dbal (v2.5.13): Loading from cache
  - Installing aimeos/aimeos-core (2017.10.15): Loading from cache
  - Installing aimeos/ai-controller-jobs (2017.10.4): Loading from cache
  - Installing aimeos/ai-controller-frontend (2017.10.5): Loading from cache
  - Installing aimeos/ai-client-jsonapi (2017.10.3): Loading from cache
  - Installing aimeos/ai-client-html (2017.10.9): Loading from cache
  - Installing aimeos/ai-admin-jsonadm (2017.10.5): Loading from cache
  - Installing aimeos/ai-admin-jqadm (2017.10.21): Loading from cache
  - Installing aimeos/ai-admin-extadm (2017.10.1): Loading from cache
  - Installing aimeos/ai-laravel (2017.10.1): Loading from cache
  - Installing aimeos/ai-gettext (2017.10.1): Loading from cache
  - Installing aimeos/ai-swiftmailer (2017.10.5): Loading from cache
  - Installing symfony/psr-http-message-bridge (v1.1.0): Loading from cache
  - Installing aimeos/aimeos-laravel (2017.10.4): Loading from cache
  - Installing filp/whoops (2.3.1): Loading from cache
  - Installing fzaninotto/faker (v1.8.0): Loading from cache
  - Installing hamcrest/hamcrest-php (v1.2.2): Loading from cache
  - Installing mockery/mockery (0.9.10): Loading from cache
  - Installing sebastian/version (2.0.1): Loading from cache
  - Installing sebastian/resource-operations (1.0.0): Loading from cache
  - Installing sebastian/object-reflector (1.1.1): Loading from cache
  - Installing sebastian/recursion-context (3.0.0): Loading from cache
  - Installing sebastian/object-enumerator (3.0.3): Loading from cache
  - Installing sebastian/global-state (2.0.0): Loading from cache
  - Installing sebastian/exporter (3.1.0): Loading from cache
  - Installing sebastian/environment (3.1.0): Loading from cache
  - Installing sebastian/diff (2.0.1): Loading from cache
  - Installing sebastian/comparator (2.1.3): Loading from cache
  - Installing doctrine/instantiator (1.0.5): Loading from cache
  - Installing phpunit/php-text-template (1.2.1): Loading from cache
  - Installing phpunit/phpunit-mock-objects (5.0.10): Loading from cache
  - Installing phpunit/php-timer (1.0.9): Loading from cache
  - Installing phpunit/php-file-iterator (1.4.5): Loading from cache
  - Installing theseer/tokenizer (1.1.0): Loading from cache
  - Installing sebastian/code-unit-reverse-lookup (1.0.1): Loading from cache
  - Installing phpunit/php-token-stream (2.0.2): Loading from cache
  - Installing phpunit/php-code-coverage (5.3.2): Loading from cache
  - Installing webmozart/assert (1.3.0): Loading from cache
  - Installing phpdocumentor/reflection-common (1.0.1): Loading from cache
  - Installing phpdocumentor/type-resolver (0.4.0): Loading from cache
  - Installing phpdocumentor/reflection-docblock (4.3.0): Loading from cache
  - Installing phpspec/prophecy (1.8.0): Loading from cache
  - Installing phar-io/version (1.0.1): Loading from cache
  - Installing phar-io/manifest (1.0.1): Loading from cache
  - Installing myclabs/deep-copy (1.7.0): Loading from cache
  - Installing phpunit/phpunit (6.5.13): Loading from cache
symfony/var-dumper suggests installing ext-symfony_debug
symfony/routing suggests installing symfony/config (For using the all-in-one router or any loader)
symfony/routing suggests installing symfony/dependency-injection (For loading routes from a service)
symfony/routing suggests installing symfony/expression-language (For using expression matching)
symfony/routing suggests installing symfony/yaml (For using the YAML loader)
paragonie/random_compat suggests installing ext-libsodium (Provides a modern crypto API that can be used to generate random bytes.)
symfony/event-dispatcher suggests installing symfony/dependency-injection
symfony/http-kernel suggests installing symfony/browser-kit
symfony/http-kernel suggests installing symfony/config
symfony/http-kernel suggests installing symfony/dependency-injection
symfony/console suggests installing symfony/lock
swiftmailer/swiftmailer suggests installing true/punycode (Needed to support internationalized email addresses, if ext-intl is not installed)
ramsey/uuid suggests installing ircmaxell/random-lib (Provides RandomLib for use with the RandomLibAdapter)
ramsey/uuid suggests installing ext-libsodium (Provides the PECL libsodium extension for use with the SodiumRandomGenerator)
ramsey/uuid suggests installing ext-uuid (Provides the PECL UUID extension for use with the PeclUuidTimeGenerator and PeclUuidRandomGenerator)
ramsey/uuid suggests installing moontoast/math (Provides support for converting UUID to 128-bit integer (in string form).)
ramsey/uuid suggests installing ramsey/uuid-doctrine (Allows the use of Ramsey\Uuid\Uuid as Doctrine field type.)
ramsey/uuid suggests installing ramsey/uuid-console (A console application for generating UUIDs with ramsey/uuid)
symfony/translation suggests installing symfony/config
symfony/translation suggests installing symfony/yaml
nesbot/carbon suggests installing friendsofphp/php-cs-fixer (Needed for the `composer phpcs` command. Allow to automatically fix code style.)
nesbot/carbon suggests installing phpstan/phpstan (Needed for the `composer phpstan` command. Allow to detect potential errors.)
monolog/monolog suggests installing aws/aws-sdk-php (Allow sending log messages to AWS services like DynamoDB)
monolog/monolog suggests installing doctrine/couchdb (Allow sending log messages to a CouchDB server)
monolog/monolog suggests installing ext-amqp (Allow sending log messages to an AMQP server (1.0+ required))
monolog/monolog suggests installing ext-mongo (Allow sending log messages to a MongoDB server)
monolog/monolog suggests installing graylog2/gelf-php (Allow sending log messages to a GrayLog2 server)
monolog/monolog suggests installing mongodb/mongodb (Allow sending log messages to a MongoDB server via PHP Driver)
monolog/monolog suggests installing php-amqplib/php-amqplib (Allow sending log messages to an AMQP server using php-amqplib)
monolog/monolog suggests installing php-console/php-console (Allow sending log messages to Google Chrome)
monolog/monolog suggests installing rollbar/rollbar (Allow sending log messages to Rollbar)
monolog/monolog suggests installing ruflin/elastica (Allow sending log messages to an Elastic Search server)
monolog/monolog suggests installing sentry/sentry (Allow sending log messages to a Sentry server)
league/flysystem suggests installing league/flysystem-aws-s3-v2 (Allows you to use S3 storage with AWS SDK v2)
league/flysystem suggests installing league/flysystem-aws-s3-v3 (Allows you to use S3 storage with AWS SDK v3)
league/flysystem suggests installing league/flysystem-azure (Allows you to use Windows Azure Blob storage)
league/flysystem suggests installing league/flysystem-cached-adapter (Flysystem adapter decorator for metadata caching)
league/flysystem suggests installing league/flysystem-eventable-filesystem (Allows you to use EventableFilesystem)
league/flysystem suggests installing league/flysystem-rackspace (Allows you to use Rackspace Cloud Files)
league/flysystem suggests installing league/flysystem-sftp (Allows you to use SFTP server storage via phpseclib)
league/flysystem suggests installing league/flysystem-webdav (Allows you to use WebDAV storage)
league/flysystem suggests installing league/flysystem-ziparchive (Allows you to use ZipArchive adapter)
league/flysystem suggests installing spatie/flysystem-dropbox (Allows you to use Dropbox storage)
league/flysystem suggests installing srmklive/flysystem-dropbox-v2 (Allows you to use Dropbox storage for PHP 5 applications)
laravel/framework suggests installing aws/aws-sdk-php (Required to use the SQS queue driver and SES mail driver (~3.0).)
laravel/framework suggests installing guzzlehttp/guzzle (Required to use the Mailgun and Mandrill mail drivers and the ping methods on schedules (~6.0).)
laravel/framework suggests installing league/flysystem-aws-s3-v3 (Required to use the Flysystem S3 driver (~1.0).)
laravel/framework suggests installing league/flysystem-cached-adapter (Required to use Flysystem caching (~1.0).)
laravel/framework suggests installing league/flysystem-rackspace (Required to use the Flysystem Rackspace driver (~1.0).)
laravel/framework suggests installing nexmo/client (Required to use the Nexmo transport (~1.0).)
laravel/framework suggests installing pda/pheanstalk (Required to use the beanstalk queue driver (~3.0).)
laravel/framework suggests installing predis/predis (Required to use the redis cache and queue drivers (~1.0).)
laravel/framework suggests installing pusher/pusher-php-server (Required to use the Pusher broadcast driver (~3.0).)
laravel/framework suggests installing symfony/dom-crawler (Required to use most of the crawler integration testing tools (~3.3).)
psy/psysh suggests installing ext-pdo-sqlite (The doc command requires SQLite to work.)
psy/psysh suggests installing hoa/console (A pure PHP readline implementation. You'll want this if your PHP install doesn't already support readline or libedit.)
symfony/psr-http-message-bridge suggests installing psr/http-factory-implementation (To use the PSR-17 factory)
filp/whoops suggests installing whoops/soap (Formats errors as SOAP responses)
sebastian/global-state suggests installing ext-uopz (*)
phpunit/php-code-coverage suggests installing ext-xdebug (^2.5.5)
phpunit/phpunit suggests installing phpunit/php-invoker (^1.1)
phpunit/phpunit suggests installing ext-xdebug (*)
Writing lock file
Generating optimized autoload files
> Illuminate\Foundation\ComposerScripts::postAutoloadDump
> @php artisan package:discover
Discovered Package: aimeos/aimeos-laravel
Discovered Package: fideloper/proxy
Discovered Package: laravel/tinker
Discovered Package: nesbot/carbon
Package manifest generated successfully.
> @php artisan vendor:publish --tag=public --force
Copied Directory [/vendor/aimeos/aimeos-laravel/public] To [/public/packages/aimeos/shop]
Publishing complete.
> @php artisan key:generate
Application key [base64:SMVIu5jgEp1EAYzKhS0ZeeShWhd5xOP3OLy0zAMzGhY=] set successfully.
> @php artisan make:auth
Authentication scaffolding generated successfully.
> App\Composer::configure
Database setup
- DB_CONNECTION (mysql):
- DB_HOST (127.0.0.1):
- DB_PORT (3306):
- DB_DATABASE (homestead): aimeos
- DB_USERNAME (homestead): aimeos_user
- DB_PASSWORD:
Mail setup
- MAIL_DRIVER (smtp):
- MAIL_HOST (smtp.mailtrap.io):
- MAIL_PORT (2525):
- MAIL_ENCRYPTION ():
- MAIL_USERNAME ():
- MAIL_PASSWORD:
> @php artisan migrate
Migration table created successfully.
Migrating: 2014_10_12_000000_create_users_table
Migrated:  2014_10_12_000000_create_users_table
Migrating: 2014_10_12_100000_create_password_resets_table
Migrated:  2014_10_12_100000_create_password_resets_table
> App\Composer::setup
Initializing or updating the Aimeos database tables for site "default"
Changing typeid of mshop_attribute table                              OK
Migrating order emailflag colum to order status list
Renaming product warehouse table                                      OK
Changing warehouseid column in mshop_product_stock                    OK
Adding ctime/mtime/user columns to tables
Renaming catalog tree table
  Checking table "mshop_catalog_tree":                                OK
Renaming order tables
  Checking table "mshop_order_address":                               OK
  Checking table "mshop_order_discount":                              OK
  Checking table "mshop_order_product":                               OK
  Checking table "mshop_order_service":                               OK
  Checking table "mshop_order_service_attribute":                     OK
Adding id to order service attribute table
  Checking column "id":                                               OK
Adding siteid to order tables
  Checking table "mshop_order_base":                                  OK
  Checking table "mshop_order":                                       OK
  Checking table "mshop_order_base_address":                          OK
  Checking table "mshop_order_base_discount":                         OK
  Checking table "mshop_order_base_product":                          OK
  Checking table "mshop_order_base_service":                          OK
  Checking table "mshop_order_base_product_attr":                     OK
  Checking table "mshop_order_base_service_attr":                     OK
Renaming global tables
Changeing locale sites to tree of sites
  Checking column "mshop_locale_site.level":                          OK
  Checking column "mshop_locale_site.nleft":                          OK
  Checking column "mshop_locale_site.nright":                         OK
Changing site ID to NOT NULL
  Changing table "madmin_job":                                        OK
  Changing table "mshop_attribute":                                   OK
  Changing table "mshop_attribute_list":                              OK
  Changing table "mshop_attribute_list_type":                         OK
  Changing table "mshop_attribute_type":                              OK
  Changing table "mshop_catalog":                                     OK
  Changing table "mshop_catalog_index_attribute":                     OK
  Changing table "mshop_catalog_index_catalog":                       OK
  Changing table "mshop_catalog_index_price":                         OK
  Changing table "mshop_catalog_index_text":                          OK
  Changing table "mshop_catalog_list":                                OK
  Changing table "mshop_catalog_list_type":                           OK
  Changing table "mshop_coupon":                                      OK
  Changing table "mshop_coupon_code":                                 OK
  Changing table "mshop_customer_list":                               OK
  Changing table "mshop_customer_list_type":                          OK
  Changing table "mshop_locale":                                      OK
  Changing table "mshop_media":                                       OK
  Changing table "mshop_media_list":                                  OK
  Changing table "mshop_media_list_type":                             OK
  Changing table "mshop_media_type":                                  OK
  Changing table "mshop_plugin":                                      OK
  Changing table "mshop_plugin_type":                                 OK
  Changing table "mshop_price":                                       OK
  Changing table "mshop_price_type":                                  OK
  Changing table "mshop_product":                                     OK
  Changing table "mshop_product_list":                                OK
  Changing table "mshop_product_list_type":                           OK
  Changing table "mshop_product_stock":                               OK
  Changing table "mshop_product_stock_warehouse":                     OK
  Changing table "mshop_product_tag":                                 OK
  Changing table "mshop_product_tag_type":                            OK
  Changing table "mshop_product_type":                                OK
  Changing table "mshop_service":                                     OK
  Changing table "mshop_service_list":                                OK
  Changing table "mshop_service_list_type":                           OK
  Changing table "mshop_service_type":                                OK
  Changing table "mshop_supplier":                                    OK
  Changing table "mshop_supplier_address":                            OK
  Changing table "mshop_text":                                        OK
  Changing table "mshop_text_list":                                   OK
  Changing table "mshop_text_list_type":                              OK
  Changing table "mshop_text_type":                                   OK
Rename warehouse table
  Drop "mshop_product_stock.fk_msprost_whid"                          OK
  Drop "mshop_product_stock.fk_msprost_stock_warehouseid"             OK
  Rename "mshop_product_stock.wareshouseid"                           OK
  Rename "mshop_product_stock_wareshouse"                             OK
Migrating order address salutations
Fixing order email status values                                      OK
Migrating order type
Changing typeid of mshop_media table                                  OK
Adding label and status columns for product warehouse
Adding status column to all list tables
  Checking table "mshop_attribute_list":                              OK
  Checking table "mshop_catalog_list":                                OK
  Checking table "mshop_customer_list":                               OK
  Checking table "mshop_media_list":                                  OK
  Checking table "mshop_price_list":                                  OK
  Checking table "mshop_product_list":                                OK
  Checking table "mshop_service_list":                                OK
  Checking table "mshop_text_list":                                   OK
Ensure unique codes in mshop_service                                  OK
Renaming shipping to costs
  Checking table "mshop_price":                                       OK
Moving product tag tables to own domain
  Moving table "mshop_product_tag_type"                               OK
  Moving table "mshop_product_tag"                                    OK
Adding tax column to order tables
Rename "prodid" to "parentid" in table "mshop_product_stock"
  Checking column "prodid"                                            OK
Move stock tables to own domain
  Checking "mshop_product_stock"                                      OK
  Checking "mshop_product_stock_type"                                 OK
Migrate product code in stock table
Renaming order base customercode to customerid
Migrating subject tables
  Checking table "mshop_subject_customer":                            OK
  Checking table "mshop_subject_supplier":                            OK
  Checking table "mshop_subject_common_address":                      OK
  Checking table "mshop_subject":                                     OK
Renaming catalog index tables to index
  Checking table "mshop_catalog_index_attribute"                      OK
  Checking table "mshop_catalog_index_catalog"                        OK
  Checking table "mshop_catalog_index_price"                          OK
  Checking table "mshop_catalog_index_text"                           OK
Renaming order base product amount to quantity
Changing typeid column of product table
  Checking table "mshop_product":                                     OK
Migrating order flags to order status list
Renaming order domain
Adding warehouse code to order base product table                     OK
Adding code column to mshop_catalog                                   OK
Renaming column "discount" to "rebate"
  Checking table "mshop_price"                                        OK
  Checking table "mshop_order_base"                                   OK
  Checking table "mshop_order_base_product"                           OK
  Checking table "mshop_order_base_service"                           OK
Renaming discount tables
Migrating configuration keys in coupon tables                         OK
Migrating product property domain to "product"                        OK
Adding parentid column to catalog and locale_site
  Checking parentid column in "mshop_catalog"                         OK
  Checking parentid column in "mshop_locale_site"                     OK
Adding label to mshop text table                                      OK
Renaming column "price" to "value"
Adding service ID to order base service table
Changing typeid of mshop_text table                                   OK
Adding product ID to order base product table
Changing "domain" columns
  Checking table "mshop_attribute":                                   OK
  Checking table "mshop_attribute_type":                              OK
  Checking table "mshop_attribute_list_type":                         OK
  Checking table "mshop_catalog":                                     OK
  Checking table "mshop_catalog_list_type":                           OK
  Checking table "mshop_catalog_suggest":                             OK
  Checking table "mshop_media_type":                                  OK
  Checking table "mshop_media_list_type":                             OK
  Checking table "mshop_media":                                       OK
  Checking table "mshop_plugin":                                      OK
  Checking table "mshop_product_type":                                OK
  Checking table "mshop_product_list_type":                           OK
  Checking table "mshop_product_tag_type":                            OK
  Checking table "mshop_service":                                     OK
  Checking table "mshop_service_list_type":                           OK
  Checking table "mshop_text_type":                                   OK
  Checking table "mshop_text":                                        OK
  Checking table "mshop_text_list_type":                              OK
Adding mtime, ctime, editor columns to coupon tables
  Checking table "mshop_coupon"
  Checking table "mshop_coupon_code"
  Checking table "mshop_order_base_coupon"
Changing code from "product" to "default" in "mshop_product_type"     OK
Renaming order columns pdate,ddate,dstatus,pstatus
  Checking columne "ddate":                                           OK
  Checking columne "pdate":                                           OK
  Checking columne "pstatus":                                         OK
  Checking columne "dstatus":                                         OK
Creating base tables
  Using schema from locale.php
    Checking table "mshop_locale_site":                               done
    Checking table "mshop_locale_language":                           done
    Checking table "mshop_locale_currency":                           done
    Checking table "mshop_locale":                                    done
  Using schema from attribute.php
    Checking table "mshop_attribute_type":                            done
    Checking table "mshop_attribute":                                 done
    Checking table "mshop_attribute_list_type":                       done
    Checking table "mshop_attribute_list":                            done
  Using schema from customer.php
    Checking table "mshop_customer":                                  done
    Checking table "mshop_customer_address":                          done
    Checking table "mshop_customer_list_type":                        done
    Checking table "mshop_customer_list":                             done
    Checking table "mshop_customer_group":                            done
    Checking table "users":                                           done
    Checking table "users_address":                                   done
    Checking table "users_list_type":                                 done
    Checking table "users_list":                                      done
  Using schema from media.php
    Checking table "mshop_media_type":                                done
    Checking table "mshop_media":                                     done
    Checking table "mshop_media_list_type":                           done
    Checking table "mshop_media_list":                                done
  Using schema from order.php
    Checking table "mshop_order_base":                                done
    Checking table "mshop_order_base_address":                        done
    Checking table "mshop_order_base_product":                        done
    Checking table "mshop_order_base_product_attr":                   done
    Checking table "mshop_order_base_service":                        done
    Checking table "mshop_order_base_service_attr":                   done
    Checking table "mshop_order_base_coupon":                         done
    Checking table "mshop_order":                                     done
    Checking table "mshop_order_status":                              done
  Using schema from plugin.php
    Checking table "mshop_plugin_type":                               done
    Checking table "mshop_plugin":                                    done
  Using schema from price.php
    Checking table "mshop_price_type":                                done
    Checking table "mshop_price":                                     done
    Checking table "mshop_price_list_type":                           done
    Checking table "mshop_price_list":                                done
  Using schema from product.php
    Checking table "mshop_product_type":                              done
    Checking table "mshop_product":                                   done
    Checking table "mshop_product_list_type":                         done
    Checking table "mshop_product_list":                              done
    Checking table "mshop_product_property_type":                     done
    Checking table "mshop_product_property":                          done
  Using schema from stock.php
    Checking table "mshop_stock_type":                                done
    Checking table "mshop_stock":                                     done
  Using schema from service.php
    Checking table "mshop_service_type":                              done
    Checking table "mshop_service":                                   done
    Checking table "mshop_service_list_type":                         done
    Checking table "mshop_service_list":                              done
  Using schema from supplier.php
    Checking table "mshop_supplier":                                  done
    Checking table "mshop_supplier_address":                          done
    Checking table "mshop_supplier_list_type":                        done
    Checking table "mshop_supplier_list":                             done
  Using schema from text.php
    Checking table "mshop_text_type":                                 done
    Checking table "mshop_text":                                      done
    Checking table "mshop_text_list_type":                            done
    Checking table "mshop_text_list":                                 done
  Using schema from coupon.php
    Checking table "mshop_coupon":                                    done
    Checking table "mshop_coupon_code":                               done
  Using schema from catalog.php
    Checking table "mshop_catalog":                                   done
    Checking table "mshop_catalog_list_type":                         done
    Checking table "mshop_catalog_list":                              done
  Using schema from tag.php
    Checking table "mshop_tag_type":                                  done
    Checking table "mshop_tag":                                       done
  Using schema from index.php
    Checking table "mshop_index_attribute":                           done
    Checking table "mshop_index_catalog":                             done
    Checking table "mshop_index_price":                               done
    Checking table "mshop_index_text":                                done
Move list types to separate table
  Checking table "mshop_attribute_option_list":                       OK
Add locale data for languages and currencies
  Adding data for MShop locale languages                              188/188
  Adding data for MShop locale currencies                             156/156
Converting "madmin_job" to InnoDB".                                   OK
Renaming in "madmin_job" column "user" to "editor".
  Checking column "user":                                             OK
Creating admin tables
  Using schema from cache.php
    Checking table "madmin_cache":                                    done
    Checking table "madmin_cache_tag":                                done
  Using schema from log.php
    Checking table "madmin_log":                                      done
  Using schema from job.php
    Checking table "madmin_job":                                      done
  Using schema from queue.php
    Checking table "madmin_queue":                                    done
Adding data for MShop locale domain
  Adding data for MShop locale sites                                  done
  Adding data for MShop locales                                       done
Adding locale data if not yet present                                 OK
Setting locale to "default"                                           OK
Renaming service domain
Renaming service configuration                                        OK
Migrating catalog suggest tables
Migrating product text and media tables to list
  Checking table "mshop_product_text":                                OK
  Checking table "mshop_product_media":                               OK
Adding typeid column to price table
  Checking column "typeid":                                           OK
Migrating configuration of "Complete" plugin                          OK
Setting label and status values
  Checking table "mshop_plugin_type":                                 OK
  Checking table "mshop_product_tag_type":                            n/a
  Checking table "mshop_service_type":                                OK
Add domain values to "mshop_product_stock_type" table                 OK
Adding time columns to order table                                    done
Migrating service price table to list
  Checking table "mshop_service_price":                               OK
Changing typeid to not allow NULL values
Creating platform specific schema
  Using tables from index-mysql.sql
    Checking index "mshop_index_text.idx_msindte_p_s_lt_la_ty_do_va": created
    Checking index "mshop_index_text.idx_msindte_value":              created
  Using tables from order-mysql.sql
    Checking index "mshop_order_base_product_attr.idx_msordbaprat_si_cd_va": created
    Checking index "mshop_order_base_service_attr.idx_msordbaseat_si_cd_va": created
  Using tables from text-mysql.sql
    Checking index "mshop_text.idx_mstex_sid_dom_cont":               created
Migrating configuration of "ProductLimit" plugin                      OK
Renaming plugin domain
Adding label column to mshop_plugin table                             OK
Changing typeid column in mshop_product_tag table
  Checking table "mshop_product_tag":                                 OK
Add stock type domain values                                          done
Migrating service text table
  Checking table "mshop_service_text":                                OK
Migrating "Complete" to "BasketLimits" plugin
  Migrating "minorder"                                                OK
  Migrating "minproducts"                                             OK
  Migrating "Complete"                                                OK
  Checking table "mshop_product_package":                             OK
  Checking table "mshop_product_package_text":                        OK
  Checking table "mshop_product_package_price":                       OK
  Checking table "mshop_product_package_stock":                       OK
Migrate suppliercode in mshop_product                                 OK
Adding MShop type data for site "default"
  Checking "attribute/type" type data                                 9/9
  Checking "attribute/lists/type" type data                           8/8
  Checking "catalog/lists/type" type data                             10/10
  Checking "customer/lists/type" type data                            7/7
  Checking "media/type" type data                                     8/8
  Checking "media/lists/type" type data                               8/8
  Checking "plugin/type" type data                                    1/1
  Checking "price/type" type data                                     3/3
  Checking "price/lists/type" type data                               2/2
  Checking "product/type" type data                                   3/3
  Checking "product/lists/type" type data                             16/16
  Checking "product/property/type" type data                          4/4
  Checking "stock/type" type data                                     1/1
  Checking "service/type" type data                                   2/2
  Checking "service/lists/type" type data                             8/8
  Checking "supplier/lists/type" type data                            4/4
  Checking "tag/type" type data                                       2/2
  Checking "text/type" type data                                      23/23
  Checking "text/lists/type" type data                                7/7
Adding default code data for site "default"
  Checking "customer/group" codes                                     3/3
Processing product demo data                                          added
Processing coupon demo data                                           added
Adding default plugin data
  Adding data for MShop plugins                                       11/11
Processing supplier demo data                                         added
Processing catalog demo data                                          added
Rebuilding index for demo data                                        done
Processing customer demo data                                         added
Processing service demo data                                          added
Adding default attribute data for site "default"                      OK
Rename "refid" to "parentid" in table "users_address"
  Checking column "refid"                                             OK
> App\Composer::account
Create admin account
- E-Mail: here_is_admin_email@some_mail.com
- Password:
Add "super" group to user "here_is_admin_email@some_mail.com" for site "default"
Add "admin" group to user "here_is_admin_email@some_mail.com" for site "default"
Post by aimeos » 05 Dec 2018, 21:29
The installation is fine and without errors and also the locale records are all there.
Your problem seems to be somewhere else, e.g. accessing a wrong/old database. Can you also provide more information about your environment like did you install Aimeos in a subdirectory of your document root? You are talking about a subdomain. Do you have more information about that? Futhermore, can you post a screenshot of the error?
Doglexx
Post by Doglexx » 06 Dec 2018, 19:44
I don't know what happened, but site "fixed" by itself.
I just left it for a 2 days, did nothing to the server and now it works fine.
I suspect it can be some timezone issues, but anyhow everything is very strange.
Thank you for help, anyhow.
In 1-2 weeks I'll try to repeat installation from the scratch, just as a test.
Post by aimeos » 07 Dec 2018, 11:52
Maybe the web server has been restarted, which clears the APCu cache ...
