Skip Delivery step
jramirezgranada
Skip Delivery step
Post by jramirezgranada » 04 Dec 2018, 20:24
Hi there;
I would like to skip delivery step on checkout depending of some conditions, How can I do it from code ? Thanks
Laravel 5.6
Aimeos Core 2018.07.12
Aimeos Laravel 2018.07.2
Jorge A Ramirez
System Engineer
PHP Developer
Re: Skip Delivery step
Post by aimeos » 05 Dec 2018, 20:57
You can combine e.g. the delivery and payment page to one and remove the output of the delivery step in the template:
https://aimeos.org/docs/Configuration/C ... kout_steps
Alternatively, you can replace the standard implementation of the checkout client and overwrite the addData() method:
https://github.com/aimeos/ai-client-htm ... d.php#L397
