Remove shipping value for a product
jramirezgranada
Post by jramirezgranada » 05 Dec 2018, 15:10
Depending on some conditions I have to remove the shipping value for a products, Do i need to do id in each method that return data to the cart ?
Jorge A Ramirez
System Engineer
PHP Developer
Re: Remove shipping value for a product
Post by aimeos » 05 Dec 2018, 21:41
You can create a basket plugin that listens to the "addProduct.before" signal:
https://aimeos.org/docs/Developers/Libr ... et_plugins
