On Click Add To Basket Pages Should Not Go To Stand Basket.
awaidqureshi
Post by awaidqureshi » 08 Feb 2019, 12:08
When I click On Add To Basket Button The Pages Should Not Go To Standard Basket . Page Should Still There Only Add To Mini Basket. How I Can Do That.
Re: On Click Add To Basket Pages Should Not Go To Stand Bas
Post by aimeos » 08 Feb 2019, 13:14
This is almost the default behavior. The product is added to the basket via AJAX and the basket is displayed as overlay. If you don't want do display the overlay, you can overwrite the JS code in your own JS file:
https://github.com/aimeos/ai-client-htm ... os.js#L869
awaidqureshi
Post by awaidqureshi » 08 Feb 2019, 13:39
aimeos wrote:This is almost the default behavior. The product is added to the basket via AJAX and the basket is displayed as overlay. If you don't want do display the overlay, you can overwrite the JS code in your own JS file:
Basically My Ajax is not working May Be Some Thing Wrong. I think Its Not Adding Product In To Cart Can U Please Mention The Default Code For Adding Product In To Cart with ajax.
Post by aimeos » 09 Feb 2019, 14:05
It's the form post that starts here: https://github.com/aimeos/ai-client-htm ... os.js#L871
